Some practical matters.
To finish up, I changed the power cord and found an easier solution to a crimped strain protector as long as I don't use the power cord as a lasso. OSH sells a power cord that fits perfectly inside a rubber grommet meant to protect it from chafing against metal. Here's the packet I bought.
I relied on a ground fault outlet and rubber gloves to keep safe during the first power up. Also before starting I used the multimeter to again test the resistance for each switch and element. Is there a way to use the multimeter to test for stray voltage on the machine itself before touching it?
