Restoration of an Olympia Cremina - Page 11
Postby hperry on Wed Mar 22, 2006 12:09 pm
They don't answer at the pace that I'm used to, but they do answer. I got an email back on an inquiry in a couple of weeks. I'm not sure that in every part of the world immediate answers to every question are viewed to be as important as they seem to be to us in the US.
What about the US distributor?
Hal Perry
hperry
Postby HB on Wed Mar 22, 2006 2:45 pm
hperry wrote:What about the US distributor?
1st-line recently added Olympia parts pages to their site for the common stuff. For anything else, you would have to e-mail sales@1st-line.com (they will not accept part orders over the phone to reduce the chance of errors).
Postby stgui2 on Tue Sep 05, 2006 3:19 pm
Hi Steve,
I was going to place this in the forum but do not find a "title" for it. Besides, it contains my interpretations that might be misleading. If you feel it should be posted, please go on and post it or let Dan post it and edit it if you or him have to. I am afraid that some of the questions raised here have been revised elsewhere but do not find an answer and dont want to be redundant.
Also I dont want to "disorder" your advice so this comment is full with pieces from several "components"
I really appreciate your page and come back after each step I give. The rubber o-ring in the group head which must be the easier to get off, broke 2 x-actos. It looks like that was your very same problem.
Photos... My Sony Cybershot has been for repair in Houston for 3 months and God knows what it will give. I am including a photo that compares the Cremina with the previous SPIDEM I have. The Cremina is much bigger.
here it is
I am rebuilding my second Olimpia Cremina 67 (the first one was stolen) and I have a couple of questions:
1. the glass water level indicator is cracked abt 7.5mm on each end. no apparent leaking but before disassembling it this part was heavily covered with Teflon tape. Can I use it like that? I know that I should change the water level indicator, it is the real solution, but living in Mexico and 1st-line not insuring against breakage, this will take at least 8 months between the moment you place the order and the time you receive the item due to red tape in customs. My question to you is: how much is possible to be flexible abt this situation? or give it a try? my concern is what Steve Robinson says: pressure and a glass tube which is 26 yrs old... I would not like to have the tube blowing if it is dangerous.
2. In the group head, when you take apart the nuts on the top and get the piston off, the tube that holds the piston in the group head seems to me to be made of a certain type of rubber, cannot tell want is the material but it is definitely not solid. I ordered the complete gasket set for the Olympia Cremina and even in the diagram I do not seem to identify ANY soft part inside the group head. To situate it, it is found above the washer "with 4 holes" that Steve told us abt in his 1st part of the webpage: repairing an Olympia Cremina. Any indications as to what this might be?
3. A suggestion for future Cremina repairers... My dentist is my friend... and I asked him for some used "dental bits" that I installed in a mini-drill. Both group head gaskets were so hard and so old that I had to "play dentist" to be able to cut them in several places to be able to break them to take them out. the x-acto also broke. Even more, after I took the old rubber part and the o-ring in the group head, I had to use thinner to be able to remove whatever was left of the rubber parts.
4. the asbestos that covered the water tank looked burnt. I took it all off and came out without any problems. Polished the tank but has some soldering on it. Made out of full marine brass quality. For what I have read in the forum, there is no need to replace the asbestos coverage. or do I need to?
thanks to all
stgui
STGUI
"also enjoy the company"
LMWDP # 075
stgui2
Postby bobcraige on Tue Sep 05, 2006 3:55 pm
1. Don't even think about this, you must replace the broken tube, don't waste your time rebuilding the machine and leave a broken tube in place. To do so would be exceedingly dangerous.
2. Above the piston is the piston rod seal. It is held into the group by an internal snap ring and a washer. This seal must be replaced as it likely will be old and tired. When this seal goes, water will leak out the top of the group. If your other seals are as hard as you say, this seal must be at end of life.
3. Be extremely careful if you do this not to touch the metal into which the seals go. It is very very easy to cut into the castings and ruin them by damaging the seating surface of the seal. An Exacto knife is a very poor and dangerous tool for this purpose. Much better is a set of varying shape hooked picks made for seal removal. They will allow you to carefully get under the seal without damaging the metal seal seats machined into the castings.
4. The insulation can be removed with no problems, it is not necessary for the machine's proper operation.
Bob Craige
LMWDP #7
bobcraige
Postby mogogear on Tue Sep 05, 2006 11:45 pm
Bob says the truth!! That glass could blow with no warning.
A seal tool might be found at an auto supply store to help you remove seals easier. Also to help you solve the sight glass problem, see if you can get an accurate measurement with a metric caliper or some such device of the outside diameter of the glass tube( I don't remember the length but I bet it is laying around the site in somebodies head!!). A suitable replacement may be found in Mexico at some coffee machine repair facility or espresso repair shop. Just a idea.
greg moore
Leverwright
LMWDP #067
mogogear
Postby stgui2 on Wed Sep 06, 2006 12:10 pm
Thanks to you both of you.
1. I was afraid of this response with respect to the tube: it could simply blow in my face. I ordered at 1st line the tube and will have to wait. Tant pis!!!
2. I got the message abt the rod seal: but is there a way to replace the piston rod seal? Steve Robinson does not talk abt this and his machine was in considerable worse shape than mine. It is surprising that when u replace ALL the gaskets, this only one is left out. Is there a mechanical restriction "why not possibly replace it"? so u would have leaks "only there", nowhere else...
3. My group head seat is very slightly scratched (abt 1/10 of mm) at one single point for abt 7 mm. and from then on I got the gasket out with the point of the x-acto. Got it from Bob: no more x-acto! Thks for telling me abt the danger but I think I was lucky.
4. it has been removed and brussed so it looks nicely gold and shows the soldering procedure which is as the rest of the machine "SOLID", very solid.
The fork lever that holds the piston has an opening width of 11 mm at the begining of the fork and 19 mm a t the top. Is this normal? if it is, no doubt the circlips wear out with the opening pressure of the fork at the end; if this is not normal, I presume I could put some pressure with a press, which shoulod be the normal width?
Sorry for the measurements in mm but I have a lot of trouble with the partition of inches and ounces and feet and... miles. Decimal system is so easy.
thks to all!
STGUI
LMWDP # 075
stgui2
Postby bobcraige on Wed Sep 06, 2006 12:52 pm
1. Good, but you really had no choice.
2. Yes of course. This is covered in Steve's article I am sure, but here is how to do it. The seal is held in place with an internal circlip. This should be removed with an internal circlip pliers to compress the circlip until it just lifts out. Next you will find a washer and then the lip seal in the well of the group casting. Push the seal out with a small wooden dowel from the top if necessary. Install the new seal (which is included in the full gasket set) with the large diameter end down into the well in the group casting. Next drop in the washer and install the circlip with the circlip pliers. When you reinstall the piston, you must be careful not to cut the lips of the seal. Steve wrapped the threaded end of the piston rod with tape to prevent the edge of the threaded part from cutting the lips. Make sure that you lubricate the shaft, all the seals and the cylinder bore lightly with DC 111 which is also included in the gasket set. Also, carefully start the piston seal lips into the cylinder so as not to cut them as you insert the piston.
3. Probably the seal will conform to this damage and still seal, but it is a potential source of a leak. This is why it is important not to damage these parts.
The fork tangs should be parallel through their length. The width at the crotch of the fork is the right dimension and so you may wish to carefully attempt to straighten the damage, but it could break. I measure about 17mm the whole length of the the fork.
Bob Craige
LMWDP #7
bobcraige
Postby stgui2 on Fri Sep 08, 2006 7:49 pm
In a previous post I indicated that for whatever reason, my fork was split 19.2mm at its end. I went to a mechanic and with the fork at hand, he confirmed what Bob had previously suggested could happen: If you force it too much to close, you might break it. Mainly if it was oversplit before. So, I bought a couple of 6mm stainless steel screws and stainless steel washers and also the bolts shown as in the picture and will have to adapt the width of the screws (between the bolts) to make the fork get relatively close to the 17mm it should have. The circlips already blew part of the axis so I have no choice but build up a solution or buy another fork which I dont think is necessary. The bolts match the bolt at the top of the axis of the piston so my solution will not look too far out of place.
thanks for all your suggestions
STGUI
LMWDP # 075
stgui2
Postby mogogear on Sat Sep 09, 2006 12:04 pm
I don't know the strength rating you should use for these "pin" replacements but there is considerable force exerted on this pins. I am thinking they won't last long before they distort or break. I was speaking to Alchemist and he was giving me some estimates of PSI forces in the range of 1,000- 1,4000 if my addled memory serves me. A hardened pin might be what you should be looking for.
greg moore
Leverwright
LMWDP #067
mogogear
Postby bobcraige on Sat Sep 09, 2006 1:27 pm
I have read your post several times and I do not understand if you broke the fork or not. Try straightening it, if you break it, you can order a new one from Olympia:
Code: 04.0134.00.00 Price: CHF 50.00 (€ 32.89) ($42.02)
No. pieces: 1 Description: FORK
In any event, these pins must be hard and so your bolt is not an acceptable solution.
Code: 04.0135.00.00 Price: CHF 4.00 (€2.63) ($3.36)
No. pieces: 2 Description: PIN
Normally, the replacement circlips are included in the gasket set, but you can order them if needed:
Code: 02.3601.06.00 Price: CHF 1.00 (€0.66) ($0.84)
No. pieces: 4 Description: CIRCLIP FOR SHAFTS @ 6MM
Bob Craige
LMWDP #7
bobcraige
PreviousNext
