Request: La Pavoni Drip Grate Scan & Measurement
- pizzigri
Sure, as soon as I get back home I can scan it for you. Hopefully I can save it into a file that retains the original dimensions , or at least close enough to replicate...
- pizzigri
Ah, how can I post a file here? Without going thru the resize process.
- pizzigri
OK, so here it is. This is the image:
and you can download it in full res here:
http://www.filedropper.com/ci2014b
Hope filedropper is OK here.
Print it in Pshop at 150dpi and it will be actual size, I believe you could build a template out of it. Let me know if it works for you!
Edited to add: ruler is a Starrett engineering inch graduated ruler, in 1/64" precision. Very accurate.
