I have now used the early 60'th Europiccola (according to some research it must be 1964) daily for three weeks. Meanwhile, the 1999 Professional has been standing cold, since I thought of learning the Europiccola. However, I have never been 100% pleased with the feeling of the Europiccola. The Professional feels more responding when pulling a shot. So, today I googled about it, and found that there are another sealing that might need to be replaced. The one tightening between the piston and the top of the group. I missed that one when I replaced the other sealings. As I have a set of different gaskets for the Europiccola, I decided to open the machine again...
... Here comes the hard part. Removing the new group gasket... I don't know if there are any good techniques for doing that, but I didn't come up with any. It took me half an hour to remove it, and unfortunately, I made it some damage. Why didn't I order two? Anyway... When the gasket was finally removed, I used the "onkel" tool again, removing the screen and then the cylinder. There it was... The sealing I missed the first time. It looked pretty stuck, but it was not as hard to remove as it seemed to be. I found a replacement seal with almost (!) the same dimensions. I gave it a try, and it seemed to fit.
Reassemble... Yeah, well, not very much struggling. I found that the damage of the group gasket was not as bad on the upper side, so I turned it up and down, hoping that it would not leak. Power on... Grind and tamp... Try pulling a shot... Voila! No leaks anywhere and the feeling was exactly like the 1999 Professional! The shot was almost a killer, but maybe a few seconds to quick. Seems like I must adjust the grinder after the seal replacement.
While spending some time on the machine, I also cleaned the steam pipe, which was totally stuck. I wondered why there was no steam at all, but that was just the head that was totally dirty. Now, yet another feature is working on this oldie.
I have never owned a better and more beautiful coffee machine, and will probably never do.
