I recently received a broken Europiccola. It's in great physical shape, but nothing happens when I turn it on. After reading around on the net, I found that the fuse could be the culprit.
Some models have a fuse which has a red reset button, however this one does not. It has a simple fuse (as shown) I purchased a replacement fuse from partsguru.com ( http://www.shop.partsguru.com/P-14A-LaPavoni-Reset-fuse-with-mounting-clip-P-14A.htm) and there are two questions I had:
1) Is it ok to replace the non-resettable fuse with one that has a reset button, like the one I ordered?
2) How do I pull the old fuse out without breaking anything? It seems to be rather brittle and a light pull and twist will not get it out, it only chips it. I just want to make sure that I don't damage any threading that might be hidden underneath the fuse by really yanking it.
Thank you so much for taking a look! I appreciate any help.
A picture of the wiring can be found here (I detached the wires from the fuse already): http://i.imgur.com/K9tsr.jpg
