Replacement pressurestat for Elektra MicroCasa a Leva, Mater XP110 or CEME?
Postby narc on Sun Nov 25, 2007 11:21 am
1. Which would you choose and why?
2. There are three electrical prongs on each of these pstats. Only two are used. What is the 3rd prong used for?
3. Based on the Mater s.r.l. data sheet there are 4 models of the XP110 available for the USA market. The differences are their test pressures and fixed differential (dead band?). All the sites that sell these units do not note which model they carry. If allowed and if any of the sponsors of this forum want to would you comment on which Mater XP110 you stock? The turn of the millenium MicroCasa a Leva I own has ~0.25bar range. The Ponte Vecchio Lusso has a 0.1bar range. They look the same to me.
LMWDP #151
narc
Postby jesawdy on Sun Nov 25, 2007 5:42 pm
narc wrote:2. There are three electrical prongs on each of these pstats. Only two are used. What is the 3rd prong used for?
Normally Open (NO) and Normally Closed (NC), see this link at Chris' Coffee.
Jeff Sawdy
jesawdy
Postby oofnik on Mon Nov 26, 2007 1:37 am
How about trying something like this? :D
oofnik
Postby HB on Mon Nov 26, 2007 10:02 am
narc wrote:1. Which would you choose and why?
Based on Jim's recommendation for eliminating the "sticky pressurestat" problems of the Semiautomatica (e.g., Elektra Semiautomatica with no heat, lights on, but no boiler pressure), I would get the CEME.
Postby narc on Mon Nov 26, 2007 9:35 pm
Dan, thanks for the link. Sounds like the C.E.M.E. is the better choice based on the quality control issues with the Mater. Sounds like a pretty straight forward switch. The pstat in the MicroCasa a Leva is the original Mater. A few years old. It started to occasionally stick a while back. Don't think it was defective. Just "premature" failure. Does anyone use teflon plumber's tape when installing the pressurestat?
LMWDP #151
narc
Postby HB on Tue Nov 27, 2007 8:28 am
narc wrote:Does anyone use teflon plumber's tape when installing the pressurestat?
Unless it's a compression fitting, yes. Even then it doesn't harm anything.
Postby bill on Tue Nov 27, 2007 10:02 am
Teflon tape is really just a lubricant for tightening tapered threads. Using it on straight threads, i.e., compression fittings isn't necessary, but, as Dan says doesn't hurt anything either.
I wasn't born in Texas, but got here as fast as I could!
bill
