www.baratza.com: skilled in the art of grinding
Replace head gasket in Olympia Cremina
Postby PKR on Wed May 27, 2009 11:57 am
I am replacing the full set of seals and gaskets in my Olympia Cremina 67. I have followed many of the posts and youtube videos. However I am having trouble with the head gasket, and I really don't want to damage the fragile piston sleeve. Steve Robinson says, "Had not everyone read my posts on how to properly remove the piston?" in his rebuild thread. I habe already removed the piston, but is there an archive of threads that would have info on replacing the head gasket ? I have removed the inner top spring clip and top gasket already.
Thanks for any help you might be able to provide.
Peter
PKR
Postby hperry on Wed May 27, 2009 12:17 pm
You might check here http://www.orphanespresso.com/index.php?main_page=page&id=11&chapter=10&zenid=72d70429c6a9021de2c1d884020fd2cd. Doug is also a good resource and he hangs around here frequently.
Hal Perry
hperry
Postby PKR on Wed May 27, 2009 6:33 pm
Thank you. That site is very helpful.
Peter
PKR
