Guess I was a little too gentle with the paint can opener. Screen popped off with a slight increase in pressure. Basically just worked around the screen perimeter with the can opener increasing leverage with each revolution. 2nd rev it popped loose. Now that I know what I'm doing the Ponte Vecchio is the easiest of the 4 machines I've owned to routinely clean the screen. Only time will tell how many cycles of removing the screen it will stand up to. Considering the low cost for this part spares are good thing to have around.
Replacement was simple. Just apply pressure to the center of the screen. When it engages you hear a little pop. Screen was relatively clean for almost 5 months (yeah I know it should have been cleaned more frequently
) of use. Bottom of piston had mild staining. Both about as dirty as a weeks use of the E61/HX machine.
Thanks peacecup. This little machine is as consistent in pulling shots as the E61/HX machine. When you figure the initial cost, the minimal maintenance and cost of maintenance (parts!!), low noise operation, the cool factor of pulling the lever and most of important the quality of espresso pulled. Better value than the vibe pump machines I've owned.
