Wow, the trip to the chrome people revealed that pricing had increased since December. Each head was estimated at $85 each for stripping -prep for re-plating- finally re-plating
The lever forks alone were $25 each... I did have a comparison with Doug ( fullsack) comparing to Nickel...... I may let him share when he is ready...
So here are the "stripped " bare - naked heads if you will... They kind of remind me of rock outcroppings with various colored spring lichen growing instead of raw brass...
First a reminder of the worn chrome head
Post chemical dip
Note the small area on the head. The Chrome-man buffed that out for me to demonstrate "visually" to me the prep his staff would have to do to the stripped head, to be ready to put the chrome back on. Actually, if you could see down to a closer resolution - he noted that fine emory cloth would be called for to eliminate the tiny pits that cover the polished area after detailed polishing - a result of the caustic chemical dip that removes the old chrome. Most of the $85 per head is labor to prep the re-chrome step! I had offered to prep my own heads to save money- never mind......
