Reaching the Zen Zone with a Two Switch La Pavoni
drgary
Postby drgary » Mar 26, 2013, 1:22 am
aasemkhan wrote:I was recently introduced to the joys of home made espresso and have just purchased a used La Pavoni brass model (Two switch). I LOVE this machine. I may not have reached espresso Zen yet, but I'm pulling respectable shots with it.
I saw this quote at the top of a thread on polishing copper and brass on a vintage dual switch La Pavoni Europiccola. Since it's off topic, I thought I'd post these tips in a separate thread and link to it. I've been in the Zen zone (the alliteration was too tempting) recently with my dual switch Pavoni. To get there I equipped it with a group thermometer and inserted an Elektra double basket, which takes a higher dose than the stock Pavoni one. On my machine I had to chop the portafilter to fit that basket but some pre-Millennium portafilters will accommodate that basket internally. I've also added a pressure gauge on top of the sightglass. These are available at Orphan Espresso. This yields completely observable boiler pressure and group temperature. I've also added a Teflon gasket between the group and the boiler to slow temperature transfer. I've dialed in a Mazzer Super Jolly so that I dose about 16.5 to 17 gm with a fine grind that I tamp only to level. The Pavoni double basket will take a slightly smaller dose but should work fine.
Here is how to do this for a single shot. I've added instructions below for temperature controlling multiple shots. I turn on both switches and when the overpressure valve starts to vent I switch on the thermometer and then watch the temperature rise on the group. I also do a brief flush to heat the group. I do some half pumps to allow steam into the top of the group. As I approach target temperature I lock in the portafilter. The half pumps don't raise the lever high enough to pre-infuse the coffee. When it gets within 2 or 3 degrees F to the target starting temperature I toggle off both switches. Without a Teflon gasket you may need to give it a little more leeway, maybe toggling off 5 degrees before target. I do one or more half pumps to get to a predetermined temperature. I then raise the lever all the way and it stays put by itself while it pre-infuses. When drops hit the cup and start to slow, this means the grounds are expanding as they absorb water. Then I do about a 20 second pull that feels like cutting through frozen butter. I don't raise the lever and pull through again. This consistently yields rich shots that taste like they were pulled on a La Marzocco machine in a fine cafe. With very bright, light roasted beans I start the pull with the group temperature reading (outside back of the bell) as high as 198F. With a darker roast but not one into second crack I may start at 193F. Coffees like Stumptown Hairbender like lower temp like that. Coffees roasted into second crack will require a much lower start temperature* to tame the bitterness. The thermometer's the most important part of this routine. The thermometer I used costs $10. The shots are completely consistent because temperature is controlled. Here are two reference links:
Adding Thermometry to a La Pavoni Europiccola
Creating Teflon Gasket for Pre-Millennium La Pavoni
Converting the Portafilter to Bottomless
I'm pulling a shot at a time and haven't recently tried pulling back-to-back shots with this machine but expect that doing so will require varying when I toggle off before reaching target temperature on a machine that's heated up. Steaming milk with the High switch on will also raise group temperature and require cooling time, but these shots are so good I'm not using milk.
* Added: Such coffees do better with the internal 175F temperature Alan Adler recommends people use with the AeroPress. I would try targeting about 170F on the outside of the group bell for these. If it still has a bitter edge, try a little cooler. Robert Pavlis, who posts below, suggests in another thread that if you have a Robusta or a dark roast you can layer it on top of a lighter roast to filter out the harsher components while benefiting from other rich flavors these may confer.
LMWDP#308
quality & service, second to none
Sponsored by Chris' Coffee Service - quality & service, second to none
rpavlis
Postby rpavlis » Mar 26, 2013, 7:19 am
The La Pavoni machines with the 1974 to 2000 group are capable of making extraordinary espresso. They also require that the user know the machine very well to do this consistently. Temperature is critical, as explained in the post above!
There are two very different portafilters on these groups. (They are interchangeable) There may be more, La Pavoni changes things a lot! The earlier machine portafilters have handles with 10mm threads, and they are made from a different alloy, either an higher content brass or some other bronze type alloy. They look like copper, but are hard like many bronzes. The later ones have a larger thread, the same thread as the group handles. I do not remember the pitch but it is M12. The ones with the large thread are deeper and can probably all use Elektra MCAL filter baskets, mine can. They were made later.
njtnjt
Postby njtnjt » Mar 26, 2013, 10:03 am
Great post - I made a very nice espresso and followed it up with a cappuccino this morning for a guest in my studio. My LPE was made in 1965 and consistently yields great results since I added the digital thermometer. I am only using 13g of Klatch house blend for beans. I am pulling them around 183 degrees.
Cheers!
-Nicholas
LMWDP #414 njtnjt
dumpshot
Postby dumpshot » Mar 26, 2013, 10:51 pm
I want a ticket to The Zen Zone!
Poor Ms. Pavoni. So beautiful, yet relegated to wallflower status as her rival, the racy red Caravel, gets all the attention. But Little Red is so eager to please! Ms. Pavoni wants to be courted, swooned, have flowers sent. And damnit, I want to send flowers, but I only have so much time before work in the morning!
In all seriousness, I have had the Pavoni for several months and still haven't gotten her dialed in. The good news is that she has been a good little steamer and my wife has become addicted to cappuccinos. So now I have a coffee partner in the house, which is nice.
I do have the thermometry hooked up. Still need the Elektra basket, Teflon gasket, shims for the lever play. Probably needs a good breakdown for cleaning and re-lubing as well. But none of this should stop me from getting to The Zone. Dr. G and others have paved the way with oodles of information sharing the secrets of how to get to her heart.
Don't worry, Ms. P. we will get there!
Pete
LMWDP #484
aasemkhan
Postby aasemkhan » Mar 26, 2013, 11:33 pm
Thanks for the tips. Just serviced my Pavoni, and I think I'm flirting with zen right now. Need to see if doing the mods on my current 8 cup is worth it or should I just wait around for a 16 cup (brass / copper of course) model and move with that one. The 8 cup will do the trick no doubt, but now I have friends demanding seconds :-)
drgary
Postby drgary » Mar 27, 2013, 1:44 am
Your call, Aasem. Refilling is no big deal. Shut off the power, bleed the pressure through the steam wand. When the pressure's all gone carefully remove the cap. Refill with warm water so as not to shock the element. Recap and power back up. I was wanting a 16 cup Professional for awhile and then was happy with the Pavonis I've got.
Of course if a Europiccola boiler isn't big enough to keep your friends entertained, why stop at a Professional? There's this six group Brugnetti Aurora sitting in the warehouse at Mr. Espresso in Oakland. It's a historic machine that was in service at the cafe where they first coined the name for the American drink called a "latte."
LMWDP#308
aasemkhan
Postby aasemkhan » Mar 27, 2013, 1:12 pm
How you tempt me! :-)
That baby is most certainly out of my budget and counter space, but a man can dream. Good call on the refill procedure. I've sort of tried it, but will do a practice run to see how many shots I can pull in succession and how long it takes. Besides, a "Zen" espresso cup [ copyright; drgary ] should be worth the wait to all my friends. After all, they don't call me "Steampunk Barista" for nothing. If not, we have a Starbucks (gasp!) about three blocks away.
I should be finished brass plating the hand wheel I added to the steam wand this weekend. Then it's off to the pursuit of espresso Zen, Dr Gary style :-)
USBC champion, voted 2009 'best micro-roaster'
Sponsored by Klatch Roasting - USBC champion, voted 2009 'best micro-roaster'
drgary
Postby drgary » Apr 17, 2013, 10:04 am
The Om Zone: The Zen of Back-to-Back Shots and Steaming
Begin by getting your back straight, chin slightly tucked, and settle comfortably onto your cushion. Cleanse the channels with a few alternate nostril breaths. As peaceful alertness settles in you're ready to learn the yoga of internal heat (Tummo) for the ancient peacock.
The method I now share with you was developed by Doug Jamieson, aka Fullsack, which he briefly documented here for the diligent student after demonstrating temperature stability for over two hours on his vintage La Pavoni.
Fullsack wrote:Using your palate as your guide, determine the ideal bar reading for your coffee. In the case of Barefoot's Element it was a cool .5 bar. Warm the machine to the desired bar setting, (if you get to 1.0 bar, with steam pouring from the safety valve, you overheated), start pulling the shot, but turn off the machine during pre-infusion and finish pulling the shot. When you are almost ready to pull the following shot, turn on the machine and repeat the process.
I tried that today with four shots in a row on my two-switch Pavoni, and it works. With a group thermometer there's increased precision. (If the starting pressure is at the lower end, say 0.5 or 0.6 bar, you may need to do a few pumps to lift water into the coffee cake. Drips at the bottom of the cup and pressure against the lever will tell you the coffee's been infused.) I then made the ultimate test, powering up both switches to steam pressure to make a cappuccino. Doing this raised the group temperature about 15 degrees F past the desired starting temperature for my coffee, all the up way to 210. Keep in mind that since my group is equipped with a Teflon group to boiler gasket your group may heat more. Perhaps others can contribute their results without that gasket. The good news is after waiting two minutes I chilled the bottomless portafilter under the kitchen tap, locked it in and this quickly brought the group back to a target temperature of 195F. With boiler pressure at target one can then pull another shot. Venting steam through the wand and locking in a cold bottomless portafilter gets you back to target in less than five minutes, where the boiler pressure/temperature and group temperature were back in equilibrium.
As Doug reminds us:
Fullsack wrote:When the machine needs a refill, wait until the pressure gauge is at 0 then slowly and carefully remove the cap and add water.
Controlling a dual switch La Pavoni for back-to-back shots is the Om Zone! :lol:
LMWDP#308
IMAWriter
Postby IMAWriter » Apr 17, 2013, 3:46 pm
Wow, temp surfing Rancil...err La Pavoni! :lol:
This guide could almost be a sticky, considering how popular these 2 switch machines are these days.
Curious: has anyone attempted to wire a p-stat or pid in one of these?
Or is that Sacrilege?
Rob
LMWDP #187
www.robertjason.com
drgary
Postby drgary » Apr 17, 2013, 3:58 pm
No, in this case it's art. Ray brought his machine to my house awhile back and it was fun to see how he'd transformed it.
La Pavoni + PID = better temperature control?
LMWDP#308
Advertisement
