I bought a Conti Comocafe from EBay:
http://cgi.ebay.com/ws/eBayISAPI....=1&item=4461320633
Contrary to the auction text, the "pump" does not work.
There is a one-way valve in the cylinder that draws water from the kettle. The problem is that it returns water as well. I am having a difficult time fixing it. I tried to draw an image of it in a drawing tool but gave up, so I will describe it (but I imagine it is a common design).
At the bottom of the cylinder there is a channel drilled to the kettle. Above this lies a disc with 8 holes around the center (which seals around the circumference with an O-ring). It screws in with a special sort of screw that has a slot in the head for the sealing washer. The center of the washer is raised so that the outside of the washer lies flat with the disc. The washer also has 8 bumps that fit into the 8 holes in the disc. (FWIW, the bumps are much smaller than it looks in the photo below. I'd guess they're 0.1-0.2 mm tall.)
The O-ring was easy to replace, but I tried replacing the special raised washer with 8 bumps with a regular washer, and it didn't quite work. I tried putting the washer inside the slot in the head as well as below it.
Any advice? I could somehow put a one-way valve on the kettle side of the channel, but I'm not sure where I would find a small one (or how to build one).
Bottom of disc:
Top of disc, bottom of washer and screw:
The old washer doesn't even look that bad to me, but it is not doing its job.
Thanks,
-Paul
