i disassembled my microcimbali up to the point of the piston spring and the lower group body. it is an older style, unlike ones i have seen in other forum posts or on orphanespresso's guide - the piston is not held in at the top with 3 bolts - it comes out the bottom. and there seems to be no clear way of unfastening the group head from the boiler / main unit.
the piston must come out from underneath - but i cannot see how to remove this part of the piston body (this is the group head, right?).... there are no screws or bolts under the group seal, through the head, or anything you can access through the boiler.
does anyone have any real experience with these machines and how to disassemble them?
the reason i am going this hard at pulling it apart is because i want to learn as much as possible about how these machines are made - i want to make one from the ground up (i have the skills, though the perseverance may be an issue....) this is why i am pulling it apart - mostly to understand. and as a sideline it is completely filthy and corroded and i want to restore it. thirdly, i am a compulsive puller-apart-er.
got to say, aluminium is awful - bad idea for a boiler....
i hope someone can help.
in thanks,
sean.
ps - i will post a proper pull-apart soon, when i have got a little further....
