by paulvin on Tue Oct 25, 2011 6:16 pm
Hi all,
I recently picked up a second la Pavoni for work. Bought the machine off eBay and when it arrived it really needed some TLC. Overall, mechanical, it was fine but I'm having a devil of a time get scale off the heating element and boiler. I have run through 2 lots of descaler, and vinegar, and still there is noticeable white flakes inside.
I read somewhere that it's not a good idea to operate the lever while descaling as this can erode the seals when using citric acid? Also can I leave the descaler in the boiler overnight or might this attack the seals? Any suggestions on a strong descaler that won't cause side effects to seals or machine?
In the process of descaling (and operating the lever) the shower screen came loose with the portafilter seal. What came out from under the screen was a black oily substance, almost like old coffee grounds mixed with...oil. The top of the Teflon piston was covered in the stuff and when operating the lever black pieces would flush out. anyone experienced something similar?
It's my first millennium machine and I'm used to the old brass piston, this Teflon coated plastic thing doesn't look like its going to last as good as my old pro.
