Problem with preinfusion on pre-Millenium Europiccola - Page 2
A haven dedicated to lever espresso machine aficionados.
Link to "Problem with preinfusion on pre-Millenium Europiccola"by Chert on Sat Dec 19, 2009 12:02 pm
Could there be something clogging the line b/w your boiler and the grouphead? It sounds like everything else in is order. Are you sure your lever is all the way up in the up position?
Flint
LMDWP #198
Chert
Link to "Problem with preinfusion on pre-Millenium Europiccola"by jrm on Sat Dec 19, 2009 1:35 pm
There's plenty of pressure without coffee in the pf, so the boiler's pressure valve probably isn't the problem. I just took the group apart again and cleaned out the water inlet holes with a q-tip and compressed air. The problem persists, so I guess I'm back to the piston seals. In the worst case, replacing them will tighten up the resistance on pulls, and if I'm lucky it may somehow fix this issue too (maybe the seals are partially occluding the water inlet holes or something). Thanks again for the help, and I'll report back once I get the new seals (will probably be a couple weeks, since I'm heading home for the holidays).
jrm
Link to "Problem with preinfusion on pre-Millenium Europiccola"by KnowGood on Sat Dec 19, 2009 9:32 pm
Please do not take offense, but is the actually lever on the "correct" way?
I only ask, because in this picture (if you click on it, it will enlarge) the handle is on upside down.
Lyndon
_________
LMWDP #251
KnowGood
Link to "Problem with preinfusion on pre-Millenium Europiccola"by jrm on Sun Dec 20, 2009 1:08 am
Yes, the lever's on correctly, and no offense taken :) I was mindful of that possibility from reading the "refeathering the peacock" thread. If only that had been the problem; it would have been a very simple fix!
jrm
Link to "Problem with preinfusion on pre-Millenium Europiccola"by ziobeege_72 on Sun Dec 20, 2009 4:15 am
KnowGood wrote:Please do not take offense, but is the actually lever on the "correct" way?
<image>
God we've all been there - well at least I have :oops:
ziobeege_72
Link to "Problem with preinfusion on pre-Millenium Europiccola"by Chert on Sat Feb 06, 2010 2:35 pm
Update: My fix of using plumber's tape to try to prevent the nylon piston from slipping seems to be a failure. This morning my pre-infusion failed. When I took the group apart, as expected, I found that the piston had rotated enough to prevent the water from entering the chamber with the lever in the up position.
I tightened it and put the thing back to together and the peacock is good to go again.
Flint
LMDWP #198
Chert
Link to "Problem with preinfusion on pre-Millenium Europiccola"by ziobeege_72 on Sat Feb 06, 2010 7:04 pm
Unfortunately this may end up being regularish procedure you are going to have to do. Not the end of the world, but a faff nonetheless. I replaced my nylon piston with a brass one and that helped things substantially. The other thing is do is to overtorque screwing the head back in with nylon plumbers tape (ie. tightening it really hard!). I did this by putting the head of a needle pliers set into the hole in the shaft, and then tightening as hard as I could with the piston head working in the opposite direction. That solved the problem.
ziobeege_72
Previous
