Some of the early "Millenium models" has nylon pistons which tended to unscrew and reduced the group capacity. The solution is either to screw it back in or replace with one of the later brass pistons.
jrm wrote:overhaul. OTOH, when I took the group apart they didn't look particularly worn or deformed. Can you tell whether they should be replaced from a visual inspection? And by what mechanism would the seals be causing this problem? Thanks again, all.
