Pressurestat purpose?
Postby cai42 on Sun Dec 12, 2010 1:13 pm
Greetings,
I broke that infamous glued wheel. If I provide the pressure on my Gaggia Factory, why do I need a pressurestat?
Cliff
cai42
Postby HB on Sun Dec 12, 2010 1:36 pm
The pressurestat regulates the pressure of the steam boiler. Without it, the boiler would either remain cold (pressurestat fails open) or heat up until it the safety over-temperature tripped (pressurestat fails closed). Your pressing on the lever pressurizes the brew chamber; it has nothing to do with the operation of the pressurestat.
Postby MattJ on Sun Dec 12, 2010 5:28 pm
to add a little to what Dan had to say...
the "stat" part is like the thermostat in your house, although instead of ambient air temperature the pressurestat responds to the pressure inside the boiler
mine for example cycles the heating element on at .6 bar and off at .85 bar
another member posted he had some luck twisting a piece of wire around the threads to simulate the threaded collar - I'm not familiar with the Gaggia but on the EP there's a little metal tab that the plastic lock nut contacts that you would need to apply pressure to with the wire to get it to work
MattJ
Postby cai42 on Sun Dec 12, 2010 6:46 pm
Greetings,
Thanks for all the information. The Factory is keeping the same setting it had before I broke the wheel. Is there any danger in NOT replacing the p-stat?
Thanks,
Cliff
cai42
Postby MattJ on Mon Dec 13, 2010 12:25 pm
I would guess that the metal tab is jammed or corroded into place by mechanical inertia. Hopefully one of the real espresso mechanics like Stefano will weigh in (I would send him a pm or email).
I would just watch it very carefully and not walk away from it when it's warming up. I don't know much about those machines at all, but it would all boil down to the safety valve (pun intended). As long as if it sticks open and leaves the element on the safety valve would release enough pressure then it won't explode although I guess it could burn out the element. Overall for safety purposes I would want the pressurestat working correctly. Guess it depends on how dangerously you like to live?
MattJ
Postby Psyd on Sat Dec 18, 2010 3:13 pm
cai42 wrote:Thanks for all the information. The Factory is keeping the same setting it had before I broke the wheel. Is there any danger in NOT replacing the p-stat?
T'were me, I'd do at least what I did when it happened to me. I took a simple cable tie wrap where the wheel used to be. IIRC, the 'looser' the p-stat is, the higher the temperature and pressure goes. No wheel at all would top it out at max, and that would concern me if it were in my kitchen.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby cai42 on Sat Dec 18, 2010 4:08 pm
Greetings,
The replacement p-stat arrived today from Stefano's Espresso so our kitchen is almost safe to be in. The Gaggia Factory must have talked to our electric stove because the oven thermostat just died. Next will be the toaster oven.
Thanks,
Cliff
cai42
