Since i don't have a pressure gauge i'm doing this theoretically, bearing in mind that pressure is force divided by surface area. The surface area is easily found. The diameter of her piston is 50mm, the radius of the circle is 2.5cm, the square of that is 6.25, times pi gives ~19.6cm^2.
Calculating the maximum force exerted by the spring was a bit harder for me to do. I don't have pressure meters that go all the way to ~200kg, but i do have a bathroom scale.
So, i put the bottom half (without kettle or group) of La Peppina on the scale and pulled down the lever. Her bottom weighs 1.7kg, and when the lever is fully down, the scale read 10.0kg. So, the force i put down on the lever was 8.3kgf.
On this diagram, its easy to see how the spring is connected to the lever
On that pic, the lever is up, and the connecting piece has an angle of ~30 degrees upwards. When the spring is fully depressed, it has an angle of 45 degrees downwards. The distance between the spring connecting rod and lever rod is 1.5cm. But at an angle of 45 degrees, the effective horizontal distance is 1.5/cos(45) = 1.1 cm. The length of the lever from the tip to the base is 30 cm (no curvature). 30/1.1 is 27.3. So the force exerted by the lever on the spring is 27.3 times as high as the force at the tip of the lever. That gives the force at the spring at 226 kgf. Which is a lot. Divided by the surface area of 19.6 cm^2 gives 11.6 bar at the beginning of the pull.
A lot more than most people thought it did. Still, i can't see any obvious flaws in my math. So it has to be somewhere in the vicinity of true.
Still don't get why La Peppina doesn't give a lot of crema.
/tries to hang with the cool kids by trying science
