by Fullsack on Fri Jul 18, 2008 9:20 am
Thanks Bob,
That is the correct switch, but my heating element is even more ancient than the one pictured, four single terminal poles, no fuse.
I believe I have the wiring configuration figured out, thanks to the continuity tester and a little bit of luck. I'll know for sure when I get it back together. I am waiting for delivery of the PTFE gasket material you recommend.
Where did you get the high temp wire sleeves? I searched for them online, but nada.
BTW: nice wiring job Bob!
Cheers,
Doug
