Low crema by itself isn't an indicator of bad espresso, but it may be an indicator of the age of the beans.
Only other change I would try is to pull lever to near fill point, then lock in the portafilter, then raise all the way and pull the shot. This always worked better for me on the pavoni.
F.M. wrote:I get one brand [of beans] for free, but find them to be marginally fresh (no date stamp). Still I use them %50 of the time to save money as I go through a lot of beans, and they are typically acceptable but never inspirational. The other %50 I get from Vivace, 1-2 days after roasting.
orphanespresso wrote: If you have your machine set at .85 for heat control there is not going to be full preinfusion to the point of drips.
timo888 wrote:With thin crema that dissipates quickly you might be overextracting because the machine is too hot. Try skipping the warming flush and see how that affects things.
