Pre-infusion in La Pavoni Europiccola
Hello fellow leverheads,
In a first-gen 1965 La Pavoni, does a 10s pre-infusion followed by drips indicate a grind which is just about right?
I am using a medium light Ethiopian currently, and I've tried up to 15s of pre-infusion with no drips. Tastewise it is great, but the lack of crema is interesting, and I wonder if I should tighten / coarsen the grind.
Grinder: Mazzer Super Jolly
Dose: 13.5g in double basket
Temp: Following drgary/rpavlis routine (flush with 4 mini-pumps when OPV whistles at Massimo, toggle to Minimo for brew).
i think taste in the cup is the most importat aspect.. if you like it then it's ok.. i usually like a finer grind/more coffe with no drips after 7-10 preinfusion. also the crema is influenced by a lot of factors (type of coffe, days post roast..). for me when i use the pavoni the feel of the lever during the pull is a good indicator of taste.. if it offers resistance the whole way down while the pour is like a "mouse tail" then usually i am in the right grind setting
- grog
Going slightly coarser will likely increase crema.
LMWDP #514
- EddyQ
Gee, I am just a beginner. But, I typically adjust grind to obtain 20 - 30 second pull time based on a lot that I have read. I have only put three different coffees through my LP so far and found the lighter roast produced drips with 5 sec pre-infuse. But my dark roast, I think I could pre-infuse all day and not get a drip. Both were ground to result with 20-30sec pull times. So with that, I stop the pre-infuse at 10-15 second for the dark roast. So far, my espresso has nice crema and taste.dilin wrote:In a first-gen 1965 La Pavoni, does a 10s pre-infusion followed by drips indicate a grind which is just about right?
LMWDP #671
- peacecup
If you are getting drips in the cup after 10 secs a coarser grind will not likely produce crema, but try it.
Ethiopian coffee has been tricky for me with my lever machines, can't get past the sourness.
LMWDP #049
Thanks for all your feedback.
It seems to be the nature of this bean; regardless the taste is in the cup.
@peacecup Yup, I enjoy the citrusy acidity in Ethiopians, but I have been drinking Ethiopians for one week straight, and am quite sick of the upfront berry notes. So I pulled it hotter than usual (6 half-pumps!) and got a smooth milk-choc shot with a hint of berries instead.
