zubinpatrick wrote:You could also add a pressure gauge (like a pav pro). I surf the temp a lot using the gauge and the on off switch......
gido wrote:thank you for your answer.
this machine does have a pressure gauge, but it only gives you the pressure from the boiler, not the pressure you are given through the lever pump.
what does high vs low pressure do? from what's i've come to understand, too high pressure gives more intense flavors, while lacking sweetness to balance it, which could be (a part of) the problem. while too low a pressure should do the opposite, ie produce bland flavors.
the pressure valve indicates between 0.8 and 1.0 bar. i will try to make some espresso at 0.8 bar, with longer pre-infusion, to lower the pressure. see if i can get a sweet cup this way. if this works, i can look further for the right balance.
still, how does one get a thicker body?
and i hope someone will explain the ins and outs of pre-infusion to me.
