Positive pressure, PID Pavoni: world domination begins - Page 2
matadero210 (original poster)
#11: Post by matadero210 (original poster) »
TUS172 wrote:So you allow water into the unit and then turn the water off to operate the unit and then between shots allow more water into the system? Otherwise you would be over pressured during operation and forcing water out the OPV ...Right or Wrong?
I have tried both ways. With the 20psi regulator, the pressure is firm but OK. The problem has to do with the size of my expansion chamber. Its about 20cc, which is too small to allow the lever to be raised easily. So, when I first fill the pavoni, the sealed boiler is filled with air at 0bar. As the water comes in, I end up with about half a boiler at 1bar of air. In this circumstance (400+20ml of air in the system), I can leave the inlet open and pull shots just fine. Over the course of 2-3 hours, however, the air gradually escapes (the Pavoni is not an air-tight design), and I am left with only 20ml of air (just like operating the pavoni with the boiler filled to the very top).
Tonight I'm installing a 500ml expansion chamber into the cold-water plumbing. Then I should be able to leave the inlet open all the time. The basic problem is the 45ml that the piston displaces when rising. With the new expansion tank, the pressure in the system should stay 20psi regardless of 100ml changes to the system.
So to your question: right when the system has leaked the air out (after a few hours) and in incompressible, wrong when there is plenty of air in the system.
I'll post a picture of the new, larger expansion tank tonight. It's overkill (.5L of air), but the stabilized pressure will make steaming easier, I think. Let you know tonight.
raj
PaulTheRoaster
#12: Post by PaulTheRoaster »
matadero210 wrote:Over the course of 2-3 hours, however, the air gradually escapes (the Pavoni is not an air-tight design), and I am left with only 20ml of air (just like operating the pavoni with the boiler filled to the very top).
Does the air escape if you idle the machine for 2 hours, or only if you use it periodically?
I ask because I was kibbitzing when we had a new boiler put in the house where I used to live. The heating man said it was okay if the radiators had some air in them, or even if they had a lot of air in them, because the air would dissolve in the boiler water, then get released in a special valve as the water cooled, and that after a few days *all* the air would be gone from the system.
(I remembered this conversation when I was thinking about saving electricity costs on my upcoming 2-group thermosyphon leva machine by not priming one of the groups.)
My Comocafe (Hi Tim!) has two rubber flapper valves, and both are water-tight, but only one is air-tight. I assumed the Pavonis used more robust valves, but maybe I'm wrong.
Edit: does anyone else get a close gvideo tag if they click submit while the edit window has the cursor?
Advertisement
#13: Post by matadero210 (original poster) »
Paul the Roaster asks about how long air lasts in my system.
Today I fired it up and the pressure release valved leaked the air out in 15 minutes (at 20psi). I glopped some silicone grease on it, and retried: it took 30 minutes this time. So I think its much less subtle than air dissolving in water. at 95C, I don't think it would happen, anyway. Not much solubility. But with the new expansion tank, air isn't needed in the boiler anyway.
Today I enlarged the expansion tank did 10 shots in a row. First, the new tank:
Then, I switched to Celsius scale, autotuned, and moved the TC wiring away from the AC. The result was improved TC stability. I also hooked up the power switch and steam switch.
The steaming works fine: its fun to heat to 120C and open the steam valve and watch the heater try to keep up (it stabilizes around 110C with the steam wand fully open after 2 minutes). Needless to say, to get to steam takes much longer (95-120c in about 2 min) because the boiler starts off cooler.
The expansion tank has resulted in much more stable pressure, so that I left the inlet valve open for 2 hours and 10 shots without issue. When I figure out how to post video, I'll put up the money shot. Its not perfect (a little blonding at the end), but a FULL 45 ml shot with 1 lever pull through 11g of 2-day-old roast ground fine, tamped very lightly:
raj
timo888
#14: Post by timo888 »
matadero210 wrote:Needless to say, to get to steam takes much longer (95-120c in about 2 min) because the boiler starts off cooler.
Suppose you steam the milk first: how long (and what volume of water) does it take to bring the temperature down to brew range by flushing with the fresh-water inlet valve open?
Regards
Timo
#15: Post by matadero210 (original poster) »
All,
I learned a new thing from the Pavoni this morning. As you know from other discussions, the pre-M piston is backed with steam (normally), while the M piston is backed with water. My system, although pre-M, is so full of water that the piston gets backed with water. This morning I noticed that if I left the machine (at temp) for 5 minutes and then dry-pumped the machine--lifting the lever almost but not quite to pre-infusion and back down--the boiler registered a 5C temperature drop. I think this is water that has cooled in the head, behind the piston, returning to the boiler. This is the reason why my machine at 95C has a burnt taste, but at 93.5 is much better and brighter (I'm still working my way down). A few dry-pumps 20 sec before pulling a shot probably heats the head to boiler temp, or very close.
So, no need to insulate the head, just dry-pump it! (ok, now you can giggle!)
raj
espressme
#16: Post by espressme »
matadero210 wrote:All,
....snip....
raj
Hi Raj,
I would agree that a lower temp in the boiler should help.
Let me offer another idea:
:?: Why not get a LED beam level indicator and use it to monitor your liquid level in the sight glass. a reflective type would probably not even show from the front. Or a through type could be small enough to be almost un-noticable. Use it to control a simple solenoid valve in your supply hose. :?:
I love the project!
sincerely
richard / espressme
richard penney LMWDP #090,
timo888
#17: Post by timo888 »
You might want to recalibrate your setup using briskly boiling water to see if it registers 100°C. 203°F boiler water temperature is not egregiously hot, and it is probably lower when it hits the puck because the group will have sinked some heat away.
On the dry-pump technique ... it is your fun toy to play with, and you can dry-pump it to your heart's content :) but if you have the machine hooked to a fancy PID, why not try to dial in the temp and flush time/volume before you introduce flying-by-the-seat-of-the-pants techniques such as "a few dry pumps" -- that path leads to the enchanted land of Oxymoron. :wink:
Regards
Timo
Advertisement
#18: Post by matadero210 (original poster) »
Timo--
Thanks for the very sage advice. My TC registers 101.6C at vigorous boil, so I was almost certainly burning the first few shots. I had no idea how inaccurate TCs could be: should I be using pt100 or something else? My most recent shots are at 93 (nominal), but I'll try lower. As for the pumping, I'm thinking that 'enough pumping that the temperature remains stable after the last one, then immediately pull the shot' is the best policy. The real issue is that vigorous pumping causes such a fast drop in temp that the PID overdoes it and overheats the boiler by 1C, which take a minute or two to dissipate. Must learn to pump gently!
raj
timo888
#19: Post by timo888 »
matadero210 wrote:Timo--
Your TC reading is almost 3°F hotter than actual. So the water is cooler than the readout. There is no unambiguous evidence that you are burning the coffee. The harshness you're tasting could be the result of insufficient rest. 2 or 3 days post-roast is a relatively short resting period.
When you let the machine come to temperature with the inlet valve open (wait for 20 minutes, say), what does the temp read? If, after 20 minutes, you lift the lever once and only once (or pull 50ml with an empty basket), what does the temp drop to? Does the heating element come on? If so, does the TC overshoot? By how much?
Regards
Timo
#20: Post by matadero210 (original poster) »
timo888 wrote:Suppose you steam the milk first: how long (and what volume of water) does it take to bring the temperature down to brew range by flushing with the fresh-water inlet valve open?
Regards
Timo
Its on the order of 100ml, but I haven't measured the volume precisely. The trick is to limit the pre-infusion flow so that the boiler doesn't cool off too fast--so I suppose the answer is 'as fast as you want'. I think you are absolutely right that this is the way to go: steam the milk first, open the inlet, dry-pump the head, and pull the shot. Thanks for the idea,
r
