peacecup wrote:Mitch, is the boiler on your CA real copper is it Sears copper (is that a Real poncho?)? That is, I read somewhere that the boiler was faux copper, made of something else and colored. Mine appears to be discolored in the photo, and I was wondering if it would clean up nicely or not. BTW, I had a look at your website - really fantastic!
PC
Hi PC,
The copper on the CA I have is a very different color than the copper of my La Pavoni Ambassador. I would think it is probably some kind of metal plated with copper. Hope your plating is still there because it is quite nice polished up.
I decided to begin restoring it again. I even got the old thermostat to work and now I can confidently say that this machine was probably a market failure because of a) lousy thermostat and b) no site glass.
I think maybe I could calibrate the thermostat if i would attach a pressure gauge to the steam wand and then set the thermostat to cut power to the element at around 1bar. for steam you just move the thermostat switch to the left and the contact is made again to bring the temp/pressure in the boiler a bit higher.
I also put the old gaskets on my messed up piston head but was missing one (the double side flange one) and forget the orientation of the gaskets so when you get the machine, I would love to see the orientation of the gaskets on the piston head.
All in all, this is a pretty nice looking machine and with a bit of work I think we will have a couple of pretty cool Spring lever machines.
All the best,
And wait till you see the suction cups on the base of the CA. pretty funny.
Ps, whats the etiquette on two restorations at the same time. Do I post on my old thread or post here. What to do?
