by peacecup on Sat Nov 08, 2008 3:44 pm
OK, here's a quick rundown of my impressions of the Export, purchased in 2004 (don't know when it was made).
Its a 110V, 800 watt, with a base plate that says "La Base". DOn't know what that means. Currently converted to 220V, but don't know the wattage. It seems to get hotter with the new heating element, so I turned down the Pstat a little.
Things I don't like:
1. The group head came with two small, but distinct, scratches, about 2mm long. They are chromed over, so I suppose they're in the brass, and came from the PV factory that way. Don't know if they chrome them there or buy them from others (if the latter one might expect to see other machines with 45mm groups, but I never have).
2. The white enamel paint came with a couple of very small chips on the edges near the base and under the cupwarmer holder. After three years the rest of the paint seems pretty durable.
3. The paint finish in the hole under the drip tray is uneven - this can't be seen, but it indicates a less-than-perfect finish. The paint on the aluminum base is still in very good condition, so its pretty durable.
4. The metal drip trays came with sharp edges on the drilled holes - I needed to emory cloth them, and no they're fine, but again, less-than-perfect finish.
5. Plastic cup warmer rim - not the nicest quality, but it is the only plastic on the machine, excepting the lever/pf handles and the cheapo PV label (which isn't really ugly, but its kind of cheap).
6. As others have noted elsewhere the metal boiler case does not fit the impeccable tolerances. The imperfections in mine can't be noticed, but others have had worse.
7. As a spring lever it operates at lower brew pressures than a manual lever. This means it really excels with fresher beans.
8. The small group size is best for 1-1.5 oz ristrettos; 2 oz, traditional doubles require 3-4 lever pulls, and this may not be optimum.
On the plus side:
1. I really like the espresso (not a mechanical aspect, but oh well). It is very easy to operate, and very versatile as far as brew-ratio, because the double basket can take a wide range of doses 10-16g+.
2. NO maintenance or operating problems whatsoever with my machine after some 1000-2000 shots. I did replace the piston seals after three years, but I think this is because they dried out during storage. Otherwise its just been olive oil on the group seal, piston linkage, and rubber suction feet.
3. The suction feet really work, and are still in good shape. These, added to the fact that the machine seems to be designed to be well-balanced during pulling, makes it ok for one-handed operation.
4. The group design is less prone to overheating than are other home levers.
5. Good steaming, done while the shot is being pulled.
6. My Mater Pstat, at least, does not seem to have had any problems so far.
7. The thermal cut-off works, as i found out when I foolishly turned the machine on without water once. DONT EVEN PLUG IT IN WITHOUT WATER IN IT!!!!
8. With some care and basic mechanical aptitude it can be maintained at home. Even as far as replacing the heating element and piston seals.
9. It is very cheap to maintain too.
That's it so far,
PC
LMWDP #049
