by orphanespresso on Wed Dec 01, 2010 7:50 am
Once you get the knobs off....I just remove the valve retaining nut and turn out the entire shaft, knob and all...but once the case if off test all the components with a multimeter set on ohms. Unhook the wires from each component and test that component...heating element, thermostat, switch, etc . Likely indeed the problem is the brain and it can be bypassed and the only thing you lose is the low water shutoff circuit....all the rest can be wired as a simple circuit from power cord through power switch then thermal safety then pstat (or pstat then thermal safety, it does not matter) then heating element back to pilot light and switch and power cord. The brain is a big pain and this is possibly why the older brainless machines seem so much better. These machines worked just fine even in the Bezzera Club format then SAMA and first generation PV, but the brain was brought in for the low water safety feature, but why have a low water feature without an autofill?
Anyway, diagnose electrical problems with a test meter and try to not diagnose with parts....saves time and money.
