Ponte Vecchio Lusso for a Duetto owner or...? - Page 3
Postby Bob_McBob on Thu Mar 04, 2010 11:38 am
One of the reasons I chose the Duetto over other similar machines is that it can eventually can be plumbed in when I'm in a more permanent living situation. Right now, it's just not feasible to be drilling holes or running water lines across the room. I see the lever to switch to plumbed pretty much every day when I dump the drip tray right before filling the reservoir with a funnel :cry:
There are other issues with large commercial single group levers, of course. Under-cupboard clearance and the large footprint can be a problem. The Bezzera 1st-line sells is over 19" tall, not including the lever base and lever itself (which could stick out, I suppose). There's also the electrical requirements, though the 120V Bezzera single group is supposedly only 1400W. The equivalent Rancilio model is speced at 3000W for the lower voltage model, which is about 27A. Why would this be preferable over a regular 240V line? Presumably either would have to be run specially.
The Lusso is still looking pretty nice for my original idea of an interesting little lever machine to play around with and possibly keep at work. I recently got a line on a reasonably-priced used unit, which unfortunately seems to have the fit problems with both wands and the manometer you mentioned. It's a little off-putting to think it would arrive that way if I bought it new, because it really isn't a cheap machine, and it makes it look pretty bad. I'm not sure how much work is involved in fixing it, especially since they arms are chromed.
Chris
LMWDP #295
Bob_McBob
Postby hperry on Thu Mar 04, 2010 11:56 am
Bob_McBob wrote:because it really isn't a cheap machine, and it makes it look pretty bad. I'm not sure how much work is involved in fixing it, especially since they arms are chromed.
Relative to other 2 group levers it is a very cheap machine. That doesn't justify the fit and finish problems which are documented from numerous sources.
Hal Perry
hperry
Postby KnowGood on Wed Mar 10, 2010 9:48 pm
Bob_McBob wrote:I recently got a line on a reasonably-priced used unit, which unfortunately seems to have the fit problems with both wands and the manometer you mentioned. It's a little off-putting to think it would arrive that way if I bought it new, because it really isn't a cheap machine, and it makes it look pretty bad. I'm not sure how much work is involved in fixing it, especially since they arms are chromed.
So... what's the verdict? You going to grab either the used machine or a new one? I've thought hard about it for days and decided that I'm sticking with plan A - which was the Lusso 2 Gruppi. If you don't end up getting the used one, and you don't mind passing the info along (especially if it's local - you in Waterloo me in Kitchener) it would be greatly appreciated.
Lyndon
_________
LMWDP #251
KnowGood
Postby Bob_McBob on Thu Mar 11, 2010 7:44 am
The machine I was offered is reasonably cheap compared to new. Unfortunately, it exhibits basically all the typical Lusso build problems I've read about (wands not lining up with holes, steam wand is bent at a completely different angle from the water wand, etc.), as well as a scratched up drip tray, missing low water level sensor,and some diy modification that left holes in the front where the model sticker used to be. I'm still considering it, because I seriously doubt I would buy a Lusso new after reading so many complaints about their quality control. I just want a cheap machine I can have fun with and possibly even keep at work.
That new Bezzera lever machine is pretty tempting, but Caffe Tech's quote was significantly higher than the end price after importing from 1st-line, which is in turn a lot higher than the basic $2000 price, after 22% tax/duty and freight shipping. Not the sort of machine you buy just to mess around on the side.
Chris
LMWDP #295
Bob_McBob
Postby KnowGood on Fri Mar 12, 2010 8:18 am
Caffe Tech wouldn't even give me a price. I emailed first about the Ellisse AL and then the B2006AL. Gave me a price on the Ellisse ($4600) but never responded back when I asked about the B2006AL.
Lyndon
_________
LMWDP #251
KnowGood
Postby grong on Fri Mar 12, 2010 12:36 pm
Just a couple of comments with regard to your observations.
On my Lusso, about 4 years old, the wands were never perfectly centered, but they made it out of the holes and don't leak.
Missing low water level sensor—my older Lusso never had one and I would not want one. I just use the sight level and fill the tank daily.
If you take off the plastic sticky badges from any Lusso you will see two small holes in the front, and also the customer's side of the casing. This is probably a leftover from how older badges with prongs attached.
grong
Postby Bob_McBob on Fri Mar 12, 2010 5:15 pm
I know the Lusso wands are often not centred on the holes, but the steam wand is bent at an angle, while the hot water wand is bent straight down. This isn't normal, is it? The low water level circuit isn't just non-existent; it was installed, then someone removed it, and moved the badge down to cover the hole where the light used to be, leaving the drill holes in the middle exposed. The drip tray is also scratched up a lot.
It's still a nice machine, but I wonder if an old Cremina would be more fun to own...
KnowGood wrote:Caffe Tech wouldn't even give me a price. I emailed first about the Ellisse AL and then the B2006AL. Gave me a price on the Ellisse ($4600) but never responded back when I asked about the B2006AL.
Sent you a PM.
Chris
LMWDP #295
Bob_McBob
Postby RAS on Fri Mar 12, 2010 5:22 pm
I was the lucky purchaser of one of Doug's Lussos. He and Barb were great to deal with, and ultimately got everything acceptably-aligned. As the machine is now (in my possession), the rubber grommet around for the hot-water tap isn't seated properly in the body of the machine, and the low-water light (I'm assuming that's what the lower left round plastic piece is... I've never run the machine low enough to see if it lights then) isn't seated completely in the face. Not a big thing - it makes tremendous espresso, and is a pleasure to use.
I'm not sure I'd have purchased a PV from anyone but Orphan. I knew that they'd make sure the machine was right, and they did (Thanks Doug and Barb). Also, the OPV mod and boiler insulation that Orphan does/offers have been much appreciated.
We all just need to sweet-talk Doug to become a regular PV dealer. He makes the machines better, and is a pleasure to do business with. With any luck, PV would do as Quickmill does with Chris (Chriscoffee.com), and make changes/improvements based on feedback from a dealer (and end-users).
Also, I have one of Doug's naked PFs, and it's a pleasure to use with the PV. I highly recommend inquiring with him about getting one.
Bob
RAS
Postby grong on Fri Mar 12, 2010 5:47 pm
"but the steam wand is bent at an angle, while the hot water wand is bent straight down."
Both should point straight down. You might get enough adjustment to straighten it out by loosening the nut that fastens the wand to the steam valve. If that worked it could be an easy fix.
And maybe a smiley sticker to cover the holes. :D
Or, maybe a Cremina!
grong
Postby mgwolf on Fri Mar 12, 2010 8:21 pm
You can probably find a used Cremina on eBay in decent shape for about what you'd spend for a new Lusso. Orphanespresso has a complete gasket rebuild set for $62 and they also have pretty complete rebuild instructions on their website. You'll end up with a top-drawer machine that you'll be happy with for decades, although you might have to rebuild the gaskets again in 10-15 years. Michael
mgwolf
PreviousNext
