timo888 wrote:Interesting. Ponte Vecchio in their documents claim the machine is always ready to brew, and that was indeed my experience, but only if it had been purged with a flush after the false pressure was bled off -- before the first pull of the day. The differences in our experiences with the machine might be explained by the pressure settings we chose -- yours "around 1.0 bar" and mine between 1.1 and 1.2 (as recommended in the PV manual).
I doubt a difference of 0.1 or 0.2 bar would account for much. While the Lusso does perform its purpose admirably, we're not dealing with a high-precision instrument. Technically the owner's manual claim is true if you make only one espresso every 30 minutes; the dynamics change if shots are pulled in succession. It could explain why they regulate it to 1.5 bar from the factory, i.e., brew temperature would be about right with zero flushing.
I've had a lot of fun working with the Lusso. It has a huge margin of error and the brew temperature management routine is uncomplicated. It's small and rugged. Frothing good microfoam is a snap. Levers are frequently branded as "hard to master" and I'm guilty of repeating that mantra in the past. But now I've evaluated two levers (Gaggia Achille, Ponte Vecchio Lusso) that are significantly easier to use than popular pump espresso machines like the Rancilio Silvia and don't have its simultaneous steam/brew limitation. A friend of mine bought the Lusso on my recommendation months ago and was pulling good shots in a few days; he even poured some respectable latte art after a few weeks.
The lesson I've (re)learned from the Lusso is that simplicity of design can work.
