timo888 wrote:If you do not purge the thermosyphon with a brief flush (an ounce will suffice) after the false pressure has been bled at startup, the Lusso's group will remain near room temperature even after a couple of hours.
I've never observed the Lusso's group remaining at near room temperature without an initial brief flush. I don't recall any of the other Smackdown participants mentioning it either. Maybe it is unique to your machine? We heard a few similar reports of thermosyphon stalls among Vibiemme owners. I don't doubt the reports, but I was never able to reproduce the problem.
When you say the Lusso "idles cold", are you speaking literally, i.e. referring to the room-temperature group and the need for a thermosyphon purge?
What I meant by "idles cold" is that the grouphead temperature drops to ~150F measured with a thermofilter (as shown in the video). Other machines I've measured in a similar manner idle around 185 to 195F. I haven't read the patent yet, but I assume the Lusso's cold nose design intentionally counterbalances the over-temperature steam boiler water during an extraction. After a long idle period, I find the Lusso performs best if it's given a short flush and then allowed to stabilize for a minute or so.
I measured that with my tongue: walked up to the machine after a few hours and directly pulled a tasty espresso with no warming flush.
Sorry, that doesn't match my experience. I used the Lusso for months without temperature measurements and the taste of the first shot exhibited classic signs of low brew temperature (sour taste, lighter crema color). This was later confirmed using a custom thermofilter. It takes very little effort to get the Lusso ready for brewing, but its walk up and pull brew temperature is too low for the blends I use.
