bill wrote:I've taken some photos of my Riviera which I think has the same or similar group to your machine. If I can figure out how to post them I'll do that.
peacecup wrote:{snip!}
Vanelis had special 45 mm tampers made for them, so I'm set there - but I suspect I've been tamping a bit too hard.
RE: releasing false pressure: I'd given some thought to just leaving the steam valve open while it heats, like an old open boiler. Its a pain to keep steaming up the place three times before pulling a shot.
{snip!}
Any idea on how to remove the dispersion screen for cleaning? it looks to me like its pressed on. Also, do you have a schematic - I plan to send a request to Vanelis and the Company if I can't find one elsewhere.
bill wrote:
1)The 'double' basket is really not; it holds almost exactly the same volume coffee as the 'single' basket on my 58mm Futurmat. The largest shot I pull on the Riviera is about 1.5 oz. and that's for a latte and usually has a lot of blonding. If I just use the lever once it pulls a little less then 1 oz. and makes a pretty darn good espresso.
