Piston polish in La Pavoni Pro
Postby mitmind on Wed Aug 17, 2011 4:35 am
Hi
After I fixed the heating element, I was waiting for the new brass piston and the gaskets, thanks to Peter the waiting wasn't too long ;-)
As you can see the old plastic piston after 10 years of heating's status
So the first some good polish
Now hard cleaning on the portafilter gasket seal
Some results :D
And build everything again to do some real tests ! !
Hope U like It
mitmind
Postby RayJohns on Wed Aug 17, 2011 4:48 am
Nicely done!
Ray
RayJohns
Postby tekomino on Wed Aug 17, 2011 4:16 pm
I hope you clean everything up obsessively since Autsol is not food safe: http://www.deep-reflection.com/sites/de...l-msds.pdf
Refuse to wing it! http://10000shots.com
tekomino
Postby mitmind on Fri Aug 19, 2011 8:27 am
Ohh yes tekomino
Of course I did, I cleaned pretty hard with a powerful soap and then y preheat water and citric acid and let it do for some like 2 hours.
After I rebuild all I run 2 complete boilers with nothing else than water
And thanks for the advise
J.
mitmind
Postby entropyembrace on Sat Aug 20, 2011 6:43 pm
tekomino wrote:I hope you clean everything up obsessively since Autsol is not food safe: http://www.deep-reflection.com/sites/de...l-msds.pdf
I'd like to polish my machine up at some point....is there such a thing is a food safe metal polish?
entropyembrace
Postby coelcanth on Sat Aug 20, 2011 11:46 pm
we have this stuff in the bike shop called 'chromax'
it's labelled as a biodegradable and non-toxic metal polish
and although not listed as food safe,
it smells just like that stuff the dentist uses to polish your teeth after a cleaning..
it doesn't work very well
coelcanth
