Peppina Redux - Page 9
Postby timo888 on Tue May 09, 2006 4:23 pm
Is your Peppina allowed into The City of the Angels?
APPROVED FOR ELECTRICAL SAFETY
CITY OF LOS ANGELES
AJ841376
FOUNDED 1781
DEPARTMENT OF BUILDING & SAFETY
timo888
Postby timo888 on Sat May 13, 2006 5:11 pm
La Peppina Plug Dimensions
timo888
Postby happytamper on Fri May 19, 2006 8:00 pm
Very happy with my La Peppina, and I am getting great shots from it.
I was wondering how it is working out for other users. For me it seems I have to pump the lever all the way down a few times before I get the water to start infusing the coffee. It also takes about two pumps to realise an espresso the size you see in the picture. The spent coffee in the portafilter is loose after I make my coffee, very different from the hard puck I get after using my Pavoni. The body of the espresso is also a little lighter but still very good.
Anyone have any similar experiences with this machine.
Mitchell
LMWDP #77
happytamper
Postby timo888 on Fri May 19, 2006 8:55 pm
happytamper wrote:Very happy with my La Peppina, and I am getting great shots from it.
Mitch,
When you depress the lever, the spring is compressed and so the piston retreats (lowers), causing water to flow down from the kettle through the ring of portholes into the space that has been created in the piston chamber. A little of the water will enter the canal that feeds the group but the water is not under any pressure (other than gravitational) at this point and so almost all of the water remains at the top of the piston chamber.
When you allow the lever to rise, the spring expands, forcing the piston up and forcing water into the group-- but only if the one-way washer is working correctly (doubled-up washers if you're using the ultra-thin striped black EPDM washers I sent you instead of the thicker gray silicone washer). The upward force of the water will cause the pliable washer(s) to cleave to the ceiling of the piston chamber, blocking the portholes, leaving the porthole that feeds the group as the only route of escape for the water. At this stage the water IS under pressure and the true preinfusion begins. Here you want to guide the lever up with your hand, to get the benefits of a gentle preinfusion.
A single-pull of the lever should draw a gross quantity of water sufficient to net a single shot. (The cylindrical filter basket is Peppina's double-basket; the single is conical.) And so for the double, after you have guided the lever upwards about two-thirds of the way on the first pull to cause the preinfusion -- you will see a few drops and then a syrupy flow for a couple of seconds--you would then depress the lever all the way down once again, allowing more hot water to fill the piston chamber. I keep the lever down so the preinfusion lasts a relatively generous ~17 seconds. The water is at the perfect temperature and so the danger of overextraction is small. Again, however, it all depends on bean, grind, dose, and tamp. At this point, the puck has been infused with water and there's more water at the ready inside the piston chamber. Now simply let the lever rise under its own power to finish the shot.
If you're NOT getting ANY drips or flow when the lever rises to approximately two-thirds of its ambit (when you first begin to feel the resistance of the tamped puck) then do one of the following, or a combination of them but with more finesse than if adjusting a single factor in isolation:
-- put less coffee in the basket
-- tamp not so heavily
-- don't grind so fine
Goopy pucks: if you use more coffee and/or tamp more heavily you end up with a well-formed rather than a goopy puck. If you under-dose and/or tamp lightly you end up with a wetter puck. If you do a double-pull you'll have water on top of the puck even if the puck beneath is well-defined and holds together on the rails of your knock-box.
Happy experimenting.
Regards
Timo
timo888
Postby timo888 on Sat Jun 17, 2006 1:34 pm
A Happy Peppina with no water distribution problems using only one thin EPDM
backflow prevention washer in the piston chamber and another single EPDM washer
in the group
Regards
Timo
timo888
Postby ghal on Thu Jun 22, 2006 9:00 pm
another_jim wrote:The Peppina has a steaming attachment which works for the 1100 watt models, but is too anemic for the 700 watt ones. I don't use mine.
Jim,
How can I tell if mine is the 700 or 1100 watt model? Thanks!
-Gene
ghal
Postby timo888 on Thu Jun 22, 2006 9:13 pm
The back of the machine will have a plate that says 1100W 110V -- near the electrical plug.
Regards
Timo
timo888
Postby timo888 on Thu Jun 22, 2006 9:53 pm
I would use the steamer with caution, however. It can chip the enamel on the inside of the kettle at the top if tightened with too much force.
Regards
Timo
timo888
Postby mogogear on Thu Jun 22, 2006 10:21 pm
ghal wrote:Jim,
-Gene
Glad to see you made it to H-B!!!!!
greg moore
Leverwright
LMWDP #067
mogogear
Postby Huskyfox on Sun Jun 25, 2006 12:58 am
Hi all, I posted this in a couple other threads, but this seems to be the largest.
I just received my first lever machine today, and I'm very surprised with the condition! I really lucked out, found someone who had hung onto this for 25 years, and only used it 4 times during that. She got it at an estate sale. I haven't tried pulling a shot yet, it needs a good cleaning out, (it even had a dead spider in the element area.) so I ordered what I need. I did some basic cleaning for now, and ran water through it, everything seems to work great.
Here are some pictures:
http://www.onestopcomputercenter.com/espresso/Peppina/
Huskyfox
PreviousNext
