happytamper wrote:When I saw the buy it now option I knew it would not be long so I just grabbed it. Sorry you missed out Mogogear but there is another one now for sale in the states.
another_jim wrote:The Peppina has a steaming attachment which works for the 1100 watt models, but is too anemic for the 700 watt ones. I don't use mine.
I think the machine is pretty perfect as a very portable straight shot maker; for a portable cappa maker, I think the europiccolo with millenium group might be the ticket. I recently scored one on ebay for a good price; but it's still in the clutches of the USPS parcel service, so it looks like it'll be after Charlotte before I can take it through its paces.
happytamper wrote:Just received my La peppina today and was happy to see that it was in fine condition with the exception of a replaced cover. It is the 220 volt unit and I plugged it into a small converter and promptly burned out the converter, I then read on the side of the converter that it was for 50 watts max and noticed the machine was 700 watts.. So i removed the burnt converter and plugged it directly into the wall with an adapter and waited, and waited, and waited. When finally (after about 1/2 hour) The temp was up to 190, I pulled my first shot.
timo888 wrote:Well, Jim, Charlotte has come and gone, and I wanted to give you a chance to spend some time alone with your Europiccolo before asking you about it. Is the temperature-stability angel perched on your right shoulder happy with the little Pavoni? Or is the cappa devil the only one smiling?
Regards
Timo
