www.baratza.com: skilled in the art of grinding
Peppina Redux - Page 13
A haven dedicated to lever espresso machine aficionados.
Link to "Peppina Redux"by timo888 on Tue Sep 15, 2009 11:35 am
coffee_monkey wrote:On my unit, the lever at it's vertical position is not stiff and I can wiggle it about 5 degrees downwards until the spring engages (feeling resistance).
Not a significant problem. But you're going to have to disassemble the machine (see below) and you can check to see whether the spring is properly seated then.
coffee_monkey wrote:What is the function of the small hole on the front bottom of the main body? It sometimes leaks water into the drip tray during machine heat up and pulling a shot.Thanks!!
Problem. The piston o-ring either needs to be replaced, or at the very least lubed with Dow 111. Most likely, replaced. Water is escaping past the o-ring and getting into the chassis. Most importantly, this is not safe. The wet machine is an electrical hazard. Use a GFCI outlet.
The small hole is for a set screw that keeps the group assembly in place inside the main chassis. It prevents the group from spinning in place.
timo888
Link to "Peppina Redux"by coffee_monkey on Tue Sep 15, 2009 12:04 pm
Is there a particular way to seat/index the spring?
The hole I am referring to is near the base of the machine and it's just a thru hole. The upper set screw hole you are talking about has no leaks. I will get the o-ring replace ASAP.
Thanks!
Ben Chen
coffee_monkey
Link to "Peppina Redux"by orphanespresso on Wed Sep 16, 2009 5:07 am
that hole near the base is a drain hole that tells you that water is getting past your piston seal and it drains into the drip tray, but then you already knew that.
If you look at the linkage on the bottom of the machine where the handle attaches to the piston arm you may be able to reduce the play by adjusting the bolt that holds the handle in place. Be careful when you release the bolt since the piston will be free with this linkage removed (make sure the group is in place since it is fairly difficult to compress the spring and reassemble if you let it get away). 5 degrees before engaging is not very much play, in fact it is pretty good. If there is no play then it is possible that the piston wil not compress the inner piston washer fully tight and the water will all leak out as the machine sits idle.
orphanespresso
Link to "Peppina Redux"by coffee_monkey on Wed Sep 16, 2009 7:18 am
Unfortunately, I did remove the lever arm when the group was out. Fortunately, the spring did not hurt anyone/anything when it was released. Getting back in, as you said, was a major pain as I learn the hard way. I had my wife stand on the piston while I tried to wedge the lever arm back in.
Anyway, so it seemed like I should not worry about the play nor the fact it did not bottom out? Does 43ml sound right for a "full stroke" of the piston?
Thanks again!!! :D
Ben Chen
coffee_monkey
Link to "Peppina Redux"by timo888 on Wed Sep 16, 2009 2:21 pm
PLEASE DELETE.
timo888
coffee_monkey wrote:Does 43ml sound right for a "full stroke" of the piston?
As the lawyers say, Asked and answered!
~43ml is "within spec".
Lever Yield Master List
timo888
Link to "Peppina Redux"by Bluecold on Wed Sep 16, 2009 4:19 pm
coffee_monkey wrote:Unfortunately, I did remove the lever arm when the group was out. Fortunately, the spring did not hurt anyone/anything when it was released. Getting back in, as you said, was a major pain as I learn the hard way. I had my wife stand on the piston while I tried to wedge the lever arm back in.
Next time, try a workmate. Worked great for me (i have the feeling i should have said this earlier :D )
LMWDP #232
My hobby: going to coffee bars and poke fun at their puny grinders.
Bluecold
Link to "Peppina Redux"by CRCasey on Mon Sep 21, 2009 5:20 pm
Ben,
I don't suppose you happened to get any pictures of the spring re-install?
Just the thought of someone doing the balancing act on a Peppina brings a smile to my face. :lol:
Black as the devil, hot as hell, pure as an angel, sweet as love:LMWDP#244
CRCasey
Link to "Peppina Redux"by samgiles on Sat Oct 10, 2009 1:44 am
Hi all,
I've been using my Peppina for the last couple of months and have really been enjoying it. However, yesterday I took the kettle off to inspect for scale and found some rust spots on the bottom rim. I'm almost certain they weren't there when I last took the kettle off. Does everyone have this problem or am I doing something wrong? Can anyone suggest a way to treat and prevent from corroding further. I've attached a picture of the affected area.
And while I'm here, can anyone recommend a glue that I can use to reattach the foil labels that are lifting? I guess it'd have to be pretty resistant to heat. Any suggestions on either topic would be very greatfully received. Thanks.
LMWDP #169
samgiles
Link to "Peppina Redux"by Bluecold on Sat Oct 10, 2009 4:04 am
I used super glue and it is still holding on. I also have the rust spots and decided that if that's all that has rusted in 40 years, i'm not really going to worry about it.
LMWDP #232
Bluecold
Link to "Peppina Redux"by espressme on Sat Oct 10, 2009 11:42 am
Rusted areas on the kettle are a given with these great little machines.
You might gently use a very fine steel wool to clean off the rust. Then rinse and dry well. Then put a bit of Dow 111 on the entire base rim of the kettle and any other spots of kettle corrosion.. That will help prevent rust from going much further. Worked for me!
-Richard
richard penney LMWDP #090,
espressme
Link to "Peppina Redux"by samgiles on Sat Oct 10, 2009 6:15 pm
Thanks guys. Dow 111 and superglue it is then. I have both of those. I also have to make up a new cable as I figured out why I was getting electric shocks :shock: That switch is a pretty dodgy area it seems to me. In the meantime, I'm getting aquainted with the Caravel. Life is good.
LMWDP #169
samgiles
Link to "Peppina Redux"by Bluecold on Sun Oct 11, 2009 8:29 am
Oh yes, the switch is very dodgy and rust-prone. At least mine was. If you've also got it from an Italian who castrated the ground pin at the plug you've got an accident waiting to happen.
LMWDP #232
Bluecold
Previous
