Peppina Redux - Page 23
Postby ddr on Sun Mar 08, 2009 9:32 pm
Thanks folks. I will have to think about it when I am next in Seattle (where the Peppina is, although the power cord showed up in a box in Chicago while I was unpacking :) ). I have been wanting to try out a PID, and so I probably will give that a try. If the immersion heater is not up to the task at least it is only a $5 experiment.
Take Care,
Dan
Dan
LMWDP #242
ddr
Postby Bluecold on Mon Mar 09, 2009 1:39 pm
I'd just use a converter plug and fill the Peppina with a hot water kettle. 350w should be enough to keep it up temperature.
LMWDP #232
Bluecold
Postby ddr on Mon Mar 09, 2009 3:12 pm
That sounds like a good idea, my kettle is 1500W and so it is very fast. Thanks for all of the suggestions folks.
Dan
LMWDP #242
ddr
Postby Bluecold on Mon Mar 16, 2009 7:50 pm
So, i've found out what FEAR stands for, its "FElice ARosio" after the man who invented the Peppina.
The earliest Peppina patent i found was from 1960.
He also designed another coffee machine with Ernesto Valente. 'Owner of Faema' Ernesto Valente.
Actually, Felice was a very busy coffeemachine inventor.
Here is the patent for the dual temp Peppina with the wide group. 1982
He also designed the Faemina (springlever) together with Valente And a massively complicated hydraulic group which looks to be fully automatic pushbutton operated.
Cool huh?
LMWDP #232
Bluecold
Postby ddr on Thu Mar 26, 2009 7:07 pm
Thanks again for posting that picture Bluecold, I was poking around on EBay today and found a PID dealer in Chicago, so I ordered a Fujitsu PXR3 for $64. I figure it will be nice to be able to pick it up local rather than ship (kind of silly since I had the La Peppina shipped from Alba, Italy). I was going to replace the element, or buy one of the Sous Vide units I see around, but I figure buying a PID separately gives me more flexibility in case I want to use it for something else later on.
Dan
LMWDP #242
ddr
Postby Bluecold on Fri Mar 27, 2009 4:17 am
My PID controller blew this morning. It went out with a bang so to say.
Apparently somebody spilled water next to it. It was soaking wet on the bottom. Unaware of that i turned it on and after a bang all the lights went out.
I took it apart and i can count 3 blown up paths, a couple of charred SMD thingy's and a molten coil.
Glad i didn't buy a Fuji PXR3.
So, no espresso for me until the new PID arrives. I was just getting the hang of it.
So, ddr, if you also make a box like i did, waterproof it.
LMWDP #232
Bluecold
Postby orphanespresso on Fri Mar 27, 2009 5:39 am
Maybe you should mount the next one on the wall!
orphanespresso
Postby Bluecold on Fri Mar 27, 2009 6:23 am
Yeah, i thought about that. I've still got a week or so to find a water resistant solution since thats how long shipping from auberins takes. Nothing bad about auberins though. Their service is great. I sent them an email because i had very weird AC line interference. When connected to the ground, or if i touched the metal parts of the Peppina, the temperature readings jumped around wildly. I got a very fast reply with some more questions, and after answering those questions i got another fast email back with detailed instructions on how to fix it.
LMWDP #232
Bluecold
Postby samgiles on Tue Apr 21, 2009 10:08 pm
Hi everybody,
I just received my very own Peppina from Italy (actually badged Piccolina). I'm just starting to clean it up. While descaling I have found a loose piece of metal wrapped around the element. It can be slid along it and looks like lead. I'll attach a picture. Does anyone happen to know or care to speculate on it's purpose/origin? I can't imagine what use it is so can I remove it?Image
LMWDP #169
samgiles
Postby ademello72 on Wed Apr 22, 2009 12:19 am
Could it be some sort of "sacrificial" metal like zinc to offset any metal type of corrosion / unusual growth build up in the water tank, similar as described is this thread :http://www.home-barista.com/levers/strange-growth-in-reservoir-t9744.html
ademello72
PreviousNext
