espressme wrote:An idea for the "Beast" group is circulation of water through it but not like the regular HX. It would be similar to the "Achille" in having a pre pull circulate kettle temperature water through and out of the grouphead to make nice nice convection in the kettle and then to fill the piston from the kettle for the shot. One pull two kills! At the exact temperature!
I do see the benefits of various kinds of circulations, Richard, but they apply to designs where you are trying to maintain the ability of the group to sink off excess heat. The Beast will not have that particular issue because
its brew water is only a couple of degrees above desired brew temperature as it leaves the unpressurized kettle. Moreover, the Beast doesn't have a massive group that could take such a channel drilled into it; the Beast's group simply holds the PF in place.
Now, the Achille's piston chamber contains cool water, according to the details revealed in the unfolding saga. With its piston upstroke, cool water in a vestibule above the piston flows
down through a tube in the piston itself into the now empty piston chamber. Then, with the piston downstroke, that cool water in the chamber is forced into the HX system. The HX system runs through the boiler and back out through the dispersion block to the puck. When cool water is pumped into the HX tube by the piston, hot water already in the HX is pushed out to the puck.
The question on the table is, what is the best way to ensure both inter-shot and intra-shot temperature stability on the Achille? Does it involve a cooling flush? How much? What's the best starting temperature on the extraction? Will a higher starting temperature keep the heating element off for a longer time, preventing temperature overshoot mid-extraction? Does bringing cool water down into the piston chamber and allowing it to linger there for 'n' seconds figure in the equilibrium equation, or are the effects of the cool water on the group's heat-sinking negligible?
Regards
Timo
