Peppina Marries MiniGaggia - Page 51
Postby timo888 on Mon Nov 27, 2006 12:34 pm
hbuchtel wrote:The kicker is that you could experiment with both flat and falling profiles.
Now that's making a virtue of necessity. If you don't have temperature stability but temperature creep (up or down as the case may be) let's savor the results? :)
The central design tenet of the Beast is a flat temperature profile. That's where it all began, way back with Jim Schulman's remarks that the Peppina's design was just too simple to overheat or fluctuate intra-shot.
To suggest a design that radically alters that core tenet of temperature stability is really to suggest a design for a whole nother machine (as we say in Pennsylvania). It's rather like suggesting the addition of a combustion engine and a propellor to a man designing a balloon. "Oh, you mean a Zeppelin?"
Regards
Timo
timo888
Postby hbuchtel on Tue Nov 28, 2006 9:27 am
Timo, explain how this HX design lacks the ability to produce a flat temp profile!
Henry
LMWDP #53
hbuchtel
Postby timo888 on Tue Nov 28, 2006 10:48 am
Henry,
You specified that the water temperature in your boiler is at espresso brewing temp, not superheated. Let's say 202°F.
As you pull the shot, cool water enters the boiler at the same rate hot water in the HX tube is leaving it. Let's say that the extraction happens over a period of 30 seconds. So if ~60ml hot water flows onto the puck, ~60ml cool water flows into the HX tube, that would be a 2.0ml /second flow rate.
I ran another crude test with the Caravel. Brought it to 200°F and then, over a period of 30 seconds, dribbled 60ml of cool tap water into the kettle. Water temperature in the kettle dropped by about 5° with the heating element on. Again, a crude test, and not apples-to-apples, but the best I can do under the circumstances.
The intra-shot temperature fluctuation might be kept minimal with the right combination of factors. With the right tweaks your design could qualify as flat enough. :)
--a fairly large volume boiler (an open kettle really since it's not under pressure)
--the HX tube is not coiled in such a way that cold water runs adjacent to hot water
--the incoming cool water is not very cold
--the heating element respond quickly to the drop in temperature but doesn't overshoot
The longer the shot (i.e. the more restricted the flow), the more stable the brew temperature would be (at least with respect to this issue of cold-water influx).
Regards
Timo
timo888
Postby hbuchtel on Tue Nov 28, 2006 8:27 pm
timo888 wrote:Henry,
Regards
Timo
Ok, good response. I hadn't thought about the incoming water affecting the temp of the water in the boiler (which would have the effect of slightly lowering the temp of the brew water in the forward part of the HX tube.
Experimentation is required, but I think a flat brew water profile (BEFORE THE WATER TOUCHES THE PUCK! that is another story!*) is obtainable.
First, for a flat enough profile: Long flat boiler with a long horizontally articulated (?) HX tube.
Why?
Boiler length: Besides the obvious ergonomic benefits (lower center of gravity), a long (back to front, not side to side) boiler (with the group at the close end) would reduce the transfer of COLD (via the water in the boiler) from the intake water to the portion of water used for brewing.
HX articulation: Keeping the length of the HX line horizontal would prevent pockets of colder and hotter water that would arise with a vertically coiled tube.
By adjusting the dimensions of the boiler and the articulation of the HX tube, these two details would be enough to keep the temp profile flat enough.
Now, a FLAT profile design: Split the boiler in two.
The first boiler would bring up a generous (several shots worth) of water to brew temp. The second would simply maintain that temperature and warm the group.
Remember that a kettle design is not perfect. Fluctuations of temperature within the kettle (heat escaping upwards, proximity to the heating element etc) mean that a "Flat" temperature profile is flat only in name.
* I'm serious about the importance of having the ability to experiment with a falling temperature profile. There is no particular evidence that a flat temp profile produces a better espresso, on the contrary many people (this is second-hand information) think a profile that starts too hot and falls is better. (I will search around for some quotes). Although flat profiles are the fashionable thing around here (perhaps with good reason), if it turns out that falling profiles are better in some way I'd hate to be stuck with a machine that couldn't do that too. (this doesn't reflect very well upon me, but hey . . . :wink: )
NOTE: Having a closed kettle rather then an open kettle would be the way to go with this HX design. Reducing (controlling) the amount of heat and water vapour lost could only be a good thing.
Henry
LMWDP #53
hbuchtel
Postby timo888 on Tue Nov 28, 2006 9:16 pm
Henry,
The horizontally articulated HX tube and oblong boiler shape seem like good ways to mitigate the effects of the cold-water influx. An additional thing would be to warm the water up before it hits the HX tube, by loosely coiling the copper feed tube from the reservoir around the outside of the dedicated pressurized steam boiler. If the steam boiler is off then you would have a slightly cooler shot.
I have had some very nice shots at 195°F and a drift of a few degrees cooler probably wouldn't hurt as long as the extraction was predominantly in the sweet spot. I mainly try to avoid overheating the shot.
Regards
Timo
P.S. By "closed" boiler I mean "under pressure" rather than "with a lid". It would make sense to put a lid on the HX boiler with a few simple vent holes in it as a failsafe against pressure buildup.
timo888
Postby hbuchtel on Sat Dec 02, 2006 9:47 am
So what do you say, Timo? Peppina marries Achille?
Henry
LMWDP #53
hbuchtel
Postby timo888 on Sat Dec 02, 2006 11:11 am
There's not a single aspect of the existing design, with the possible exception of the drip-tray-grate :) that could remain as is, if the heat-exchanger kettle were retrofitted onto it, Henry. So why not start a new thread? It would be fun to have two designs going at once. The design you've proposed, with its displaced piston and hydraulic/gravity feed, is much closer to the Conti Comocafe. So why not get that storyline going? Achille and the little Conti :wink: And anyway, Peppina is occupied at the moment with MiniGaggia; she is his constant companion and shows no signs of fickleness.
Regards
Timo
timo888
Postby hbuchtel on Sat Dec 02, 2006 9:52 pm
timo888 wrote:There's not a single aspect of the existing design, with the possible exception of the drip-tray-grate :) that could remain as is, if the heat-exchanger kettle were retrofitted onto it, Henry. So why not start a new thread? It would be fun to have two designs going at once. The design you've proposed, with its displaced piston and hydraulic/gravity feed, is much closer to the Conti Comocafe. So why not get that storyline going? Achille and the little Conti :wink: And anyway, Peppina is occupied at the moment with MiniGaggia; she is his constant companion and shows no signs of fickleness.
Regards
Timo
Alrighty, will do.
There are a few elements which would be shared, I imagine, such as the lever assembly allowing for both manual and spring power.
I don't know much about the Comocafe, the one (?) user here hasn't found a PF for his I believe, so I'll keep the Peppina reference if you don't mind!
Henry
LMWDP #53
hbuchtel
Postby timo888 on Sun Dec 03, 2006 10:17 am
hbuchtel wrote:Alrighty, will do.
Henry
I don't own a trademark on the Peppina name, Henry. But one could wish you weren't treating her as a broodmare :roll:
The Comocafe's design resembles the Peppina's, but in addition to the reversed piston, it has the tubing and one-way valving closer to what your design will require. There is also a degree of visual resemblance between the Comocafe and the Achille, both of which use clear-glass reservoirs on the top of the machine.
The Comocafe is pictured in the Incomplete List of Gravity Levers thread. The machine is described somewhere here on the forum.
The Comocafe's brew water is drawn by gravity and suction down from the kettle through a tube and into the piston chamber. The piston pushes the water up through a tube and then out to the group. A backflow-prevention valve prevents the water from being forced back into the kettle.
Now, if the Comocafe had a cool water reservoir placed behind its kettle, or on the side of the machine opposite the lever for better balance, water could be drawn from the reservoir, through the HX-kettle, and down into the piston chamber.
You might even insert a thermoblock between reservoir and HX kettle to bring the water up to temperature, using the HX-kettle either to raise the water a few more degrees to the desired temperature or to absorb excess heat if the thermoblock had overshot the mark. You might then be able to use the same thermoblock for steam as well, using the HX-kettle to buffer the undershot and overshot temperatures.
Most impressive, like the Centre Pompidou in Paris, the HX's copper coil works would be visible through the glass :)
Regards
Timo
timo888
Postby hbuchtel on Sun Dec 03, 2006 11:14 am
timo888 wrote:I don't own a trademark on the Peppina name, Henry. But one could wish you weren't treating her as a broodmare :roll:
Very well, out of respect for La Peppina's chastity I will rename it. :)
I think I found the thread you were talking about- Pump on Conti Comocafe does not work.
Regards
Timo
Git them ideas over to Conti marries Achille!
Henry
LMWDP #53
hbuchtel
PreviousNext
