Regards
Timo
P.S. I'm superimposing several 'views' in this quick-and-dirty drawing. You're seeing a cross-section at the upper o-ring and a frontal view on the bottom o-ring. The bottom o-ring is made of a new see-through material
timo888 wrote:Is there a functional reason behind chrome-plating brass? Or is that purely aesthetic? If the latter, I'd like the group to be naked brass please.
Regards
Timo
timo888 wrote:Mathias,
In the design I have in mind, the one-way valve assembly (I call it the 'group cap') is a threaded cylinder with a plate which contains the array of egress ports and the valve(s). The group cap connects the bottom of the piston cylinder to the top of the group cylinder, which protrudes into the boiler. The group-cap is a fairly extensible design and it could accommodate other kinds of one-way valves. It's not clear to me where the one-way valve fits in your diagram and I'm not familiar with the All-Clad one-way valve. Could you describe it?
I am certainly a proponent of simplicity. The group should be very simple. It needs a cylinder that projects up into the boiler, and collar to bolt it to the underside of the boiler, and a cylinder on the bottom into which the PF locks. The water will be at the correct temperature and so we don't need anything fancy in the group. No thermosyphons etc etc. I would like to be able to make use of readily available OEM portafilters.
Regards
Timo
mathias wrote:Timo, do you know how to design the o-ring seating (diameter and tolerances)? I never found information on that.
... Eugster/Frismag of Switzerland has recalled about 28,000 automatic espresso coffee makers. The company says that the electrical connectors in the espresso machine can erode and pose a fire hazard. Eugster/Frismag has received four reports of fires started inside the coffee maker, but no reports of injuries or property damage. The espresso machines were sold through department stores and independent specialty stores nationwide from July 1999 through October 2005 for about $800.
timo888 wrote:Are there advantages to the finned valves used for rockets other than inexpensive manufacture? Can they be made of stainless steel to minimize the galvanic corrosion issue? Would they be better and/or cheaper than NSF61-compliant EPDM (assuming it would pass regulatory muster)?
If NSF61-compliant washers would be acceptable nowadays to the various regulatory agencies that monitor food service equipment for food-safety compliance, then they present the least expensive and simplest alternative. There are also bushing type valves like the one pictured below which comply with the European Pressure Equipment Directive of 2002 (not sure if that directive applies to domestic/commercial food/beverage equipment and appliances):
Could the group be made of stainless steel? What are the heat properties of stainless steel?
