timo888 wrote:The group cap shown earlier is a retro 'low-tech' design that uses a simple pliable washer as the one-way valve. Here is a more high-tech version of the group cap which has been tapped with holes into which modern one-way check valves (not shown) would be fitted. We want excellent water flow from the piston chamber down to the dispersion screen so there are multiple check valves to increase the total effective orifice diameter.
image: http://www.aimsdata.com/tim/espresso/beast/BeastGroupCapHighTech444.jpg
Tim,
I have to disagree with you on this one. Only because of my recent diassembly of my Silvia ( now sold---alsa...) After preping my Rancilio Sivia for sale, I took the dispersion screen off etc. The area under the mesh dispersion screen hasis an inverted brass mushroom inserted into the main water orfice ( or golf ball marker looking insert that acts to keep the water from being directed straight into the screen and into the puck surface. This mushroom has grooves eminating from the center and radiating out to the edges. Maybe 6 or 8 grooves.
See if you can get a look at this arrangement because the washer would act as the same type of diverter and move the water out to the edges . Here it would flow back to the area under the washer and fill the entire void above the screen. Giving an even flow.
I most likely have described this poorly , but see if a search of a site like wholelattelove on cleaning tips etc shows this. It may have an impact on your design ideas and then again....maybe not so much:oops:
One is just much more clean in design, less servicable parts. In an area as prone to build up etc , the washer would be very self-cleaning. That my vote!!
