mindless_fool wrote:what do you pavoni pro users have your presurestat set to?
uscfroadie wrote:My P-stat is set to about .75. I flush a little water through after bleeding off false pressure and letting it warm up a second time. Too long of a flush and I'll start seeing flashing (too hot). If you plan on pulling a few shots, turn off the machine in-between pulls and on again before pulling the shot to let it come up to temp again. It won't take long at all if the timeframe is under 5 minutes.
r-gordon-7 wrote:When you refer to your Gaggia Factory's P-stat setting - do you mean the gauge reading at which the boiler cycles off or do you mean the reading at which it kicks back on again after having shut off? ( I have two otherwise identical Gaggia Factory 106's, each with a seemingly very different factory P-stat setting - which I've left as-is... The first one cycles off when it hits ~1 bar and back on again when it drops to ~.85 bar. The second one cycles off when it hits ~.75 bar and back on again when it drops to ~0.5 bar. Is your "off to back on again" cycle range similar to this or more narrow...?)
BTW, how long do you find you need to keep the steamer valve open to bleed off the false pressure?
Thanks.
