I am sure there is only one gasket, not sure if it is round or square but the one Doug puts on looks to be round.
oliverkuehberger wrote:ok - even if this sounds stupid :
once the piston is back in the group there are two gaskets going, right?
so it would be gasket -screen - gasket? This is how I read it from the diagram. I had it disassembled a while ago but thought that how it was. so assuming the above is correct I have:
gasket square - screen - gasket square (I also have a round one and tried that as well)
Cannon - I am not sure I understand - I had everything disassembled and then put together again. when you say low - could you explain to me what you mean?
Thanks so much.
