Hi Doug, I tested the element and it reads about 48 ohms, which is spot on for a 1000W element at 220V. No shorts evident. The readings on the microswitch on the pstat were unstable. The male spades on this switch attach via screws that thread into terminals. I disconnected the male spades and tested the screw receptacles on the switch and got an over limit reading with the switch unengaged and a low (0.3) reading when it was engaged. This suggested the switch was fine and the contacts dirty. So, I cleaned the spades. After that the meter read the same with the spades screwed in as with them out of the switch. I figured I had fixed the problem. However, I still get no heat. I can adjust the set screw on the pstat and hear the switch engage and disengage and still no heat. I will go over the rest of the wiring harness tomorrow, but I am a bit confused. Any ideas, or should I just plug away with the main switch (which does light), and the rest of the harness? There is the issue that this element has an odd receptable in the element base in addition to the two main leads. You can see it in the picture. The red wires lead into this receptacle, which is a copper tube that contacts the main element in the interior of the boiler. I am unsure if this could be part of the problem. However, with the main two boiler leads detached the element tested fine.Return to Lever Espresso Machines
