Colin,
It's funny, I was just thinking of you this weekend as I finally got my Cremina up and running again (thanks to all those that offered their advice on a separate thread). As far as I know, we're the only two folks around here to have had the pleasure of this set up:
Now I'm starting to mess around with the Cremina again, though I'd have to agree with an earlier statement of yours, the Eurobar seems much more forgiving.
I'm consistently able to get great crema (and shots in general) from the Cremina, but I find it seems to run a little hot and rarely gives me the solid dry pucks I get from the Eurobar.
Often times, they're soggy or pock-marked, leaving considerably more grounds stuck to the dispersion screen.
One thing I've found interesting is that my baskets are interchangeable between the two machines with no real noticeable difference in performance. At this point, I'm no longer even sure which basket belongs with which machine. Grinds also seem to be pretty similar, but as you can see from the photo my grinder is functional, but nothing fancy. Also, I should add that I'm far from an espresso sommelier - as long as what I make is as good as the local hipster joint I'm happy.
Now that the Cremina is online, I'm hoping to tackle a rebuild of the Eurobar one of these days, though I've got an Olympia Club that's next in line.
All in all, the Eurobar is still my favorite, though I'm still holding out hope that Olympia will blow my mind one of these days with either the Cremina, Club or Caffarex (though it remains to be seen if my Caffarex can be saved).
Oh - I nearly forgot to chime in re: pressurestat settings. I'll double check next time I use it, but I'm quite certain it's .9 with a little floating depending on the mood of the machine.
