I had no troubles removing the piston on my machine: just remove the lever- and tap it all out?
But my machine does have the more modern style filter screen set up- so that may make a difference.
I had No problems. Only trick thing is removing the little circlip inside to change the small v-section seal in the top of the head. If you have the correct special pliers this is also a breeze.
but the group head welded directly to the boiler is an issue for me: on my machine there is tiny pinhole leak on the seam directly the group head neck.
To braze it I would want to remove the group but that doesn't look possible?
I was wondering if there was any type of metal tape (aluminum?) that I could make a tiny batch out of and place inside the boiler. The leak is so tiny- I thought this just may be the (easy) solution? But is there such a tape? Type of stuff you want if you are an cosmonaut working on MIR- to make quick (but good) repairs- from the inside- on the fly.
here is the machine:
and the leak is below the group head on the boiler:
The leak is so insignificant and tiny - it only shows up when the machine is at its highest pressure- just before the release kicks in. Even then it is barely anything. But it is annoying.... it hisses a little...
