P-stat vintage LP
- cuppajoe
That looks to be a Marcf machine rather than a Pavoni. The early LP's had a screw on element plate, and the base and rear water inlet are proper for a Marcf. You do mention a Graziella in your list.
Out of curiosity, where did you pick up the element? Wish there was enough room on the new replacement element assemblies for the LP's to use elbows like that for the Pstat.
David - LMWDP 448
. ........ CUPPAJOE , this machine is a marcfi / picola made in spain under license from LP [1971-75] AND marketed in usa using names la graziella or la cara ; 80 per cent of parts are LP or slightly different variations , the main difference being the 4 bolt cremina style group to boiler connection ; uses same brass sleeve ame as 1st gen. LP,uses SAME exact switch and very similar 2 element HE , saety valve and steam assembly , etc.
.... the elbow and street L are 1/8" npt and are very small ,small 1/4" tapped hole , with more fine threads, very easy install ; the boiler HE base very similar to MCAL AND ALSO BOLTED ON , the single element HE from 1st line equip. > LELIT $49.96 include shipping .........this whole set-up should be adaptable to 1962-79 LP's with screw-base type, where there is no HE REPLACEMENT AVAILABLE and can not be sourced anywhere ...
- drgary
One thing concerning about that heating element is it appears to extend high into the boiler. The elements for La Pavoni and similar levers is very short. These heaters need to be completely immersed in water or they self-destruct.
LMWDP#308
LMWDP#308
...... pic of HE is enlarged ; the HE actually EXTENDS from mounting plate > 2 1/4 inches < /
- drgary
2 1/4 inches to the top? If so that's pretty good.
LMWDP#308
LMWDP#308
..... replacement 1000 watt HE Is small compared to ones cut-out , the diameter is only 2 inches / recommended by PETER BRADLEY [UK] on his website AVICENNA .....
- drgary
2 inch diameter is good.
Is 2 1/4 inches the measurement from the heating element plate to top of heating element? I ask this in case others consider that heating element versus the current versions for these machines.
LMWDP#308
LMWDP#308
..... measured with caliper > 2.3 inches / 58-59 mm , to the top of the collar that sits against base plate ....
