Do you let the lever go and let the spring do the work or do you use it to reduce, increase the brew pressure?
I'll take the OP's question as a non-rhetorical question, Tekomino.
Since I have had a spring group (CMA, October 2010) I had always let the spring do the work and stopped with blonding or according to time by removing the cup. At times, recently I have begun to fill the group with water before locking in and/or limit the flow a bit with reducing the lever. More recently, I added an inner spring to one CMA group. Some shots seem to have more definition than the very agreeable but sometimes muddy shots of the standard. But others seem to have more of a "bite" and remind me of shots from the Pavoni. My limited experience of less than 10 days raises the hypothesis that I may like to have the stronger group available for single origin coffees roasted lightly (is it accurate to call this a Scandinavian roast?) and the standard group for more typical espresso roast blends. As the Scandinavian roast profiles spread for espresso blends** I may like having the stronger group available.
If you find that you prefer the taste of the shots under less pressure, can one of the springs be removed from the M20 group to lower the starting pressure? How many seconds during a good extraction before the pressure reduces below 9 bar?
(**might we see this development from roasters in 2012? -- I mean espresso blends that cause my Pharos to slip because the beans are roasted lightly?)
