One hole steaming tip for the Elektra Microcasa a Leva?
Postby boren on Sun Dec 26, 2010 8:34 am
I'd like to try a one-hole tip instead of the three-hole tip that comes with the machine. Will the Silvia tip fit? If not, is there another type that will?
Thanks! :-)
boren
Postby Carneiro on Sun Dec 26, 2010 8:42 pm
I don't think Silvia's tip can work, as the thread of the MCAL's tip is female and Silvia's is male.
I think the tip OE sells for Pavoni could fit. But maybe is not exactly the same thread...
Márcio.
Carneiro
Postby DrDregs on Mon Dec 27, 2010 1:07 am
The Pavoni tips will fit - at least they did on my McCal. A one-hole on the Elektra won't cut it. You can experiment if you want but three or two hole tips work best.
Happy steaming!
"24 hours in a day, 24 beers in a case. Coincidence? I don't think so."
DrDregs
Postby boren on Mon Dec 27, 2010 2:36 am
DrDregs wrote:The Pavoni tips will fit - at least they did on my McCal. A one-hole on the Elektra won't cut it. You can experiment if you want but three or two hole tips work best.
Can you share more details about how the one-hole tip works on the MCAL? I'd expect it to provide more control than the three-hole tip.
boren
Postby DrDregs on Mon Dec 27, 2010 8:14 am
A one hole tip for these machines is unnecessarily slow. There's no advantage other than you get to stand there for ages admiring your Lecky - not a bad thing in itself but eventually you want coffee. The Leva three-hole can be ferocious and quick but controllable with practice.
The 2 hole tip is a bit like a mature mistress - knows you haven't got all day but won't just blow bubbles either.
As I said before, play around by all means. You may decide a 1 hole is okay for you. These machines are very personal devices - everyone has a different hand for the lever. With their little industrial farts and quirks we each find our own way with them.
Enjoy the journey.
DrDregs
Postby JohnB. on Mon Dec 27, 2010 10:28 am
DrDregs wrote: The Leva three-hole can be ferocious and quick but controllable with practice.
What boiler pressure do you run to see these traits? I've got the 3 hole tip on my 08 & neither term comes to mind when I'm steaming milk. :lol:
LMWDP 267
JohnB.
Postby DrDregs on Mon Dec 27, 2010 7:58 pm
Maybe ferocious isn't the right word. Certainly more than ample for a small domestic lever anyways. From memory the McCal I was referring to ran at around 1 bar.
When I finish restoring what's going to be an all chrome with brass pigeon Lektra I'll lock it in around .9 bar.
A man's at least gotta have a two hole tip.
DrDregs
Postby cannonfodder on Tue Dec 28, 2010 10:50 pm
Elektra is one of the best at balancing steam performance with the boiler/heater combination. They also make steaming about as easy as easy can be. Take a 12 ounce pitcher, put 5 ounces of milk in it, put the steam wand dead center of the pitcher. The seam where the tip mates with the wand, put that just below the surface of the milk and open the valve. A few seconds later you have a pitcher full of microfoam. Normally, you do not need to surf the tip on the milks surface like many machines. Just put it in the milk and open the valve.
cannonfodder
Postby DrDregs on Wed Dec 29, 2010 3:44 am
cannonfodder wrote:Elektra is one of the best at balancing steam performance with the boiler/heater combination. They also make steaming about as easy as easy can be.
I couldn't agree more. My semiautomatica and the Leva can put some commercial machines to shame. Both use the same steam arm with three hole tip. The only reason I can think of for using a one hole tip is to tame a full commercial machine for domestic use.
DrDregs
Postby michaelbenis on Wed Dec 29, 2010 5:06 am
I agree with Dave and Don. I'd leave it be. Works just fine as it is. Or - to put it another way - if it ain't broke, don't fix it.... :D
LMWDP No. 237
michaelbenis
Next
