This post follows on from this thread: How do you reset the red safety switch on an Olympia Cremina?
The 'mystery' I refer to in the title to this thread is that my Cremina is now up and running perfectly, but I don't know what I have done to fix it. I haven't installed the new thermal safety switch I ordered form OE because it hasn't arrived yet. Whether I do install it when it arrives depends on whether it is really necessary to do so.
So the story is as follows. As I said in the original thread I ran the Cremina without water causing it short circuit. Well, at least, that's what I thought because upon refilling the Cremina and turning it on the fuse kept blowing, turning off not only the Cremina but the whole kitchen, forcing me to reset the fuse at my apartment's fuse box. Testing the safety switch and the element on the machine according to Doug's instructions at http://www.orphanespresso.com/Olympia-C...565-1.html indicated that something was wrong.
So, with a bit of help from a friend who knows how to repair electrical gadgets I then took out the element and tested it and found, lo and behold, that it was working. It did heat up some water. So, the element itself was good in that it worked out of the Cremina but wouldn't work when installed in the machine. This lead me to believe the problem lay with the thermal safety switch.
Next, I took out the safety switch, which wasn't easy because the screw was frozen. I had to break the screw that held the safety switch in as well as holding the yellow earth wire in place. (See photo of my machine BEFORE I did this and compare to the photo below).
The safety didn't looked fried so I then put it back but now had to hold it in place with a metal piece connected to one of the six cap bolts (see upper cap bolt in photo) I also reattached the earth wire but not as before to the safety switch, but to another cap bolt (see lower cap bolt in photo)
Now the bottom of the Cremina looks like this
Whereas originally it looked like this
In the midst of all this I took the time to replace the old boiler gasket which must have been the original one; that is, a mere 38 years old! Anyway, after reassembling the machine and filling with water I reluctantly turned it on, expecting another short circuit. But no, the machine works fine and has been doing so for the past couple of days. I've tested it under all conditions including leaving it on for hours. It idles between 0.6 and .08 bar so the pressurestat is working as before since this is sweet spot as far as I am concerned.
So I ask what did I do to fix the original problem? Clearly the element is OK, so if there is an issue it must be (or have been) with the thermal safety switch. Either that switch has reset itself, or isn't working at all. If it isn't working at all, then what stops the machine from overheating? The pressurestat? As I said before, the pressurestat does work and the machines idles within my desired range.
Robert
