The rocker switch on my 1973 Cremina, if not broken, is not working too well. If I press it down the red light will come on (thus indicating it is 'on') but when I release my finger from the switch the red light goes out (thus indicating it is 'off'). This means the machine won't stay on unless I hold the switch down, which is, of course, impractical. The globe is fine; it is the switch itself which won't stay down in the 'on' position without added pressure.
Here is a pic of my machine indicating which type of rocker switch it has.
The question is what to do? I service the machine myself and can do most things except stuff connected with the electronics. This is clearly not an electronical problem, but a mechanical problem with the switch not being able to hold itself in place. Still, I'm not keen on going in there myself to fix it (unless someone here tells me it is easy, and gives me a step by step guide).
So the issue is who can I go to for help? Can an ordinary electrician fix it? Should I take it to the local Pavoni service people? They used to service my Europiccola before I learned to do it and, in fact, once fixed my Pavoni rocker switch when it had a similar problem? Any other suggestions?
Obviously if the switch needs to be replaced any ideas where I could get one from that would fit EXACTLY in place.
thanks
Robert
