Olympia Cremina rebuild - Page 2
Postby robert mayrand on Wed Feb 17, 2010 8:40 pm
The on/off switch now on the machine is the new Olympia Cremina switch from the factory, since the square one is not available anymore. It doesn't matter what you order from them this is the switch you'll get.
Rob
LMWDP #274
robert mayrand
Postby robert mayrand on Wed Feb 17, 2010 9:47 pm
I think my Cremina was waiting to get an homage like this before giving me semi-god shot. Just after writing this I pulled a double, about 14g of black cat, light tamp, the pull was smooth with a constant pressure. The crema flowed in beautiful stripe of burgundy, chocolate and dark cream. The shot was velvety smooth and delicious with a long rich aftertaste. Certainly the best espresso I had this year, all 1.7oz of it.
Semi-god is just a way to leave place to improvement!!!!!
Rob
LMWDP #274
robert mayrand
Postby orphanespresso on Thu Feb 18, 2010 2:23 am
Excellent outcome Rob! Congratulations! No wonder you had so many questions :wink: Looks great and from the sound of it, works great as well.
orphanespresso
Postby roastaroma on Thu Feb 18, 2010 4:24 am
Beautiful work, Rob -- you really earned that Cremina! Long may the espresso flow!
"Non è la macchina, è la mano."
LMWDP #223
roastaroma
Postby mhoy on Fri Feb 19, 2010 11:34 pm
Really enjoyed reading your rebuild post. Bringing a machine back to life makes it a special machine. It also gives you a great story when you pull shots for friends!
Mark
mhoy
Postby espressme on Sat Feb 20, 2010 12:07 am
That was a great rebuild and a greater article about it!
-Richard
richard penney LMWDP #090,
espressme
Postby SwingT on Sat Feb 20, 2010 11:47 am
Great rebuild!
Really nice!
Question about the switch you got from the factory. Just curious in case mine ever goes out.
Did you have to make some sort of adapter to get the switch to fit the hole?
Or is it a "drop in" replacement?
SwingT
Postby robert mayrand on Sat Feb 20, 2010 3:53 pm
The switch is a drop in replacement, no adjustments needed. It is of course for the square hole switch, if you have the older rectangular hole with the witch and the pilot light on the same plate it won't fit.
Rob
LMWDP #274
robert mayrand
Postby sweaner on Sat Feb 20, 2010 4:06 pm
Rob, fantastic work and beautiful pictures!
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby SwingT on Sat Feb 20, 2010 7:22 pm
I've got the square hole - Mine's an 87 model.
Thanks for the response, I knew that some models were unobtainium, but wasn't sure which.
SwingT
PreviousNext
