orphanespresso wrote:With your gasket, where, as in the clock face, does the pf lock? About 4 o clock is good..I have seen 3 o clock, but this is a bit far.
The odds are good that if this is an OEM gasket that it is designed to fit the newest machines in the long history of Creminas and it is flat on one side and rounded on the other...if this is the case, which way did you install it...this could matter.
OK, I've done my repairs and time to report back.
Doug, as usual, was on the right track. On taking out the gasket I had installed I discovered that I had put it in with the rounded side facing in. Clearly it should be the other way round. Anyway, I didn't have any OEM gaskets left so I installed one of Doug's portafilter gaskets which happen to be flat on both sides. To cut the chase, problem solved. The portafilter stays in place during the shot and I'm happy again. (Holding the portafilter in place with my right hand and pulling the shot with my left was literally killing my left shoulder. Now I can revert to my earlier method of using both hands to pull the shot).
So case closed, and its off to the orphanespresso website to order a couple more portafilter gaskets for the future.
